Author Topic: Good quality HF spectrum analyser  (Read 3185 times)
Offline rchTopic starter
  • Country: wales
« on: February 25, 2016, 12:09:57 am »
I have been reading with interest the thread on getting a first SA.
https://www.eevblog.com/forum/testgear/first-spectrum-analyzer-new-rigol-used-hp-on-ebay/
I think I have similar requirements to the poster except that the main project I want it for is working between 2MHz and 30MHz.  I do however need good amplitude accuracy, reasonable frequency accuracy (though I suppose I can check with a Rigol scope I have), a reasonably narrow resolution bandwidth (no experience to be sure how narrow, but certainly below 1kHz) and decent noise performance as one of the jobs I will be doing involves setting up low noise amplifiers for low signal transducers.
Are there any decent second hand machines around with a low maximum frequency or would only very second rate spectrum analysers or very old noisy and unstable analogue ones be available in the sub 100MHz region?   Do I have any reasonable options additional to the options discussed in that thread?  Is the Rigol still a good contender on a low budget for my needs?  I'd rather pay much less!
Many thanks for any comments.
Tac Eht Xilef
  • Guest
Re: Good quality HF spectrum analyser
« Reply #1 on: February 25, 2016, 12:58:54 am »
Tip: old microwave system analysers can sometimes be found for cheap, especially if not paired with their transmitter. They're designed for comissioning/testing microwave links using the 70/140MHz IF, so generally span 100Hz to 300MHz with RBW & VBW from 100Hz to 300kHz, reasonable gain / attenuation / noise figures for HF use, etc.
Downsides: usually 75ohm, no service info available. The first can be worked around; the second is why they're often so cheap :-\
  • Country: wales
« Reply #2 on: February 25, 2016, 01:03:52 am »
That's interesting.  Are they made by the big test equipment firms, or are they more specialised or local firms?
Tac Eht Xilef
  • Guest
« Reply #3 on: February 25, 2016, 01:40:07 am »
Most of the ones I've seen have been from the more telco/comms focussed manufacturers e.g. Anritsu (now Wiltron, or visa-versa - I forget), Wandel & Goltermann, R&S, etc. I also recall HP made some, and no doubt others as well.
A quick look around doesn't show anything particularly cheap at the moment, though in the recent-ish past I've seen models like the Anritsu ME538L or ME4510B go for <AU$200 fairly regularly.
Offline cncjerry
« Reply #4 on: March 05, 2016, 02:20:27 am »
I have an Advantest but love the old HP gear as I have an HP 8568b.  I would look for an HP 3585a if you want maximal performance for the HF only range.  You can find them sometimes on Craigslist and obviously EBay.
  • Country: wales
« Reply #5 on: March 05, 2016, 08:41:09 am »
Thanks for all the suggestions - I'll keep looking for a bargain!
