Author Topic: LeCroy HVD3102 (Differential Probe) will work with TEK MDO3000?  (Read 4014 times)
Offline onesixrightTopic starter
Hi All,
Maybe a stupid question, forgive me.
As stated in the subject, any change it will work (since it uses the ProBus)? I know LeCroy have a adapter to connect TEK probes to LeCroy, but i didn't find one for vice-versa.
Thanks!
Offline Wuerstchenhund
  • Able to drop by occasionally only
Re: LeCroy HVD3102 (Differential Probe) will work with TEK MDO3000?
« Reply #1 on: July 28, 2016, 11:43:54 am »
I don't think there's an adapter to get a ProBus probe onto a Tek scope. LeCroy itself only has the TPA10 which as you know goes the other way around (Tek probe on LeCroy scope), and for it to work it also relies on support by the scope's software, so it's a bit more than just a piece of hardware.
I very much doubt there's anything like that from Tek.
« Reply #2 on: July 28, 2016, 01:02:07 pm »
Thanks, i thought so :(
Offline robert_
« Reply #3 on: July 28, 2016, 01:29:04 pm »
Some simple active probes would work given a +-12V supply, however the HVD31xx does use the I2C bus for control (range switching, offset) too. It might be possible to make something (problem being that ProBus isnt really documented, and TekVPI is even worse), but theres nothing that would work right out of the box.
Offline MarkL
« Reply #4 on: July 28, 2016, 07:48:28 pm »
I have a similar problem as the OP but with a different probe.
If no official documentation, has anyone done any reverse engineering on the ProBus protocol?
« Reply #5 on: July 28, 2016, 08:13:24 pm »
ProBus uses I2C so it shouldn't be too difficult to sniff it. The challenge is to find out how the probe is controlled, especially if you don't have a LeCroy scope. And even if you have managed to find out, you still have to make your Tek scope talk to the probe in the expected format.
I'm not sure that is really a sensible way. You might be better off selling the LeCroy probe and buy the Tek equivalent which fits your scope.
Or sell the Tek and get a LeCroy  >:D
Offline MarkL
« Reply #6 on: July 28, 2016, 09:44:01 pm »
It's a DS1855A DA1855A diff probe amplifier, so it's still operable without using the ProBus connection.  Not quite as bad as the OP's situation.
If the protocol was available, I could interrogate the settings to set the vertical scale appropriately via either SCPI or, hack up an old probe compensation box and put the right resistance on the ID ring.
As it is now, it's an annoyance and a source of error that eventually results in "Oh, yeah..." moments.  Buying an old, near-death LeCroy to figure out the I2C piece may still happen.
I really hate these proprietary, lock-'em-in probe interfaces.  They're all guilty of it.
Edit: Typo in model number.
« Last Edit: July 29, 2016, 02:24:05 am by MarkL »
Offline robert_
« Reply #7 on: July 29, 2016, 12:57:38 am »
First, have a good look at whats inside as it might be quite easy to figure out how it works. An AP015 current probe for example just uses a regular PCF8574 I2C port extender to control all of its innards, and an 24C02 for ID.
Oh, the ProBus has an pin (upper right) that is connected to the BNC "ring" too, and many probes just use an resistor there to set attenuation. Same R values as for Tek and Agilent too. There also are "reserved" values that select wether it is an "intelligent" probe so the scope reads from I2C.
With some luck, all it would take is to connect that pin to the BNC ring on your tek.
At the moment, i am working on converting an Tek P5205 to ProBus (so the other way round), which does seem to be quite successful so far. The 5205 seems to run fine on +-12V (Tekprobe is +-15 but on the scopes i tested, it was more like +14 -14,5). I know i could buy an TPA10, just its way overpriced and i cant justify to pay 1k for something i can build for <5% of that price. Plus its interesting to see whats possible and what not, just as it is with all that software...
If your probe were a HVD3106, i would happily swap that P5205 ;) and maybe even throw in that hugely overpriced TekVPI to Tekprobe adaptor.
« Last Edit: July 29, 2016, 08:20:58 am by robert_ »
The following users thanked this post: MarkL
Offline MarkL
« Reply #8 on: July 29, 2016, 02:22:33 am »
Oh, the ProBus has an pin (upper left) that is connected to the BNC "ring" too, and many probes just use an resistor there to set attenuation. Same R values as for Tek and Agilent too. There also are "reserved" values that select wether it is an "intelligent" probe so the scope reads from I2C.
That was worth a try - thanks!  But unfortunately, there's no resistance on the upper left pin, or any of them for that matter, that changes when I change the attenuation on the probe amp.  So, it must be communicating changes via I2C.
I'm afraid it's going to take a LeCroy scope to figure this out by watching the I2C conversation.
Does your 5205 change a pin resistance on the TP2 interface for 50x vs. 500x?
Offline robert_
« Reply #9 on: July 29, 2016, 08:20:11 am »
Yes, but only when its powered up.
UPDATE: Its the upper right pin. I looked at the wrong layer in the PCB, too late in the evening...
270Ohms sets some flavour of "smart" probe (that is used with all i have).
If it uses i2c, i would not be too surprised to find a PCF8574 or similar in there to read back the attenuation setting, so open the probe/amplifier box before investing much time in analysing the bus communications.
« Last Edit: July 29, 2016, 09:04:18 am by robert_ »
