Now to the blunt end of the review, how does it actually feel in use, do I need a Ph.D a alien cryptography to actually use this thing? Is it any good? And accessioned questions
The week it actually arrived I was knee deep in preparations for a large UK show so my initial time with the FPL was limited to examining to looking at both 2.4Ghz & 5Ghz wifi channel hopping on the local internal networks coupled with channel power as well as occupied bandwidths.
So in fairness not much ‘getting your teeth’ into a juicy measurement prospect, however the FPL preformed faultlessly, even when using four traces on a quite a tight RBW of 1Khz, the FPL produced fast, clean and clear screen presentations that were easy to decipher and intrepid instantly. With occupied band width & adjacent channel power again, this was easily rendered. The Lower screen table read outs were very clear and contained all the information you need to know.
I used the EMI application to check a new PSU we are working on, and compared this to the two other SA we have here, again this FPL has very solid bench performance no question at all.
Limit lines and moveable markers are a breeze to use again it very intuitive to use, compared to the not so intuitive set up procedures we have on one of the others SA units.
The one aspect I was looking forward to using was the noise figure app, unfortunately I didn’t have a NRP sensor in the with the loan unit. I did briefly play with the Vector signal explorer app, this gives you access to some of the lesser VNA functions as apposed to the full gamut that its brother ZNLE VNA carries. However give the abilities of this unit, it generally very good performance and price point. I would suggest it stands up very well against much of the opposition.
One of the finial sessions with this unit was tracking down some spurious RF interference on a well-loved expensive digital to analogue converter for a client using H & I probes. Using just the internal pre amp and no external amplification. With ref level set to between -10 & +10 dBc, so far no need to use the external pre amplifier or transient limiter.
The instrument is very fast & responsive here and it’s so simple to readjust the span/ frequency bands of interest quickly. The simplicity of the app selection and ease of swapping again first rate, this has really been thought out from the (END USERS perspective, not the coders point of view imho) The trace lines are clear & concise and easy to interpret even with 4 of them in the mix, peak & marker tables again simple and clear to read.
Although I didn’t have the necessary time to check out all of the features the FPL spectrum analyser has, I personally felt I managed to obtain a very good handle on its use, quirks and day to day running, its abilities and limitations and most of all its personality.
So rounding up then, this is one of more straightforward pieces I have written the FPL spectrum analyser is one of those products that really does what it says on the tin without fuss or having to navigate thirty six drop down menus while standing on a three legged chair over a precipice.
Likes: There are a lot of them.
Small neat form factor great for both bench and mobile applications
Great solid decent performance for the cost
Models from 3 to 26.5Ghz
Simple and easy to use GUI
Top quality screen & touch facility
Lots of quality apps available including:
EMC pre compliance /VSE/Analogue mod/Noise figure/Power measurements/BER with PRBS data/Multi modulation
Track generator option
Noise measurement option you don’t normally see at this price point
The set-up flow chart to guide you through correctly setting up for a specific measurement attribute.
Battery pack for mobile use (optional).
Dislikes
No HDMI output
No IF output
No phase noise measurement (maybe wishful thinking)
No low frequency extension to 10Hz again suspect that is part of the R&S range structure.
I’m struggling to think of more, but at the moment no its not really a unit you don’t like at all, its been engineered to be very appealing and useable across a wide range of disciplines.
This FPL analyser really is a damn fine jack of all trades with really solid performance and I pretty sure it’s hard to beat at this sector of the market for flexibility and abilities.
Gets the Sighound seal of approval, if you are thinking of having a quality all round damn fine spectrum analyser for your lab then I would suggest a demonstration I’m sure you will be surprised by it potential. Solid B+ all day.
