Correct. The 2204A is what I am thinking.
Yes, at this point in time, the GW-Instek GDS2204A is quite a bit cheaper than the Rigol DS4024 - although I suspect Rigol may drop their prices in the not-too-distant future (just as Agilent has quickly introduced new 'options' for the X2000 series in response to Instek).
The main difference between the Instek and the Rigol (aside from VGA output and other non-essential things) appears to be the memory size - and the desirability of that in the work that you do. I do a lot of data-stream logging and analysis, so a large amount of memory for segmenting is fantastic and I couldn't bear to live without the 56MB in my Rigol - I've gotten so used to it
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
- but for most DSO users it's irrelevant.
BTW, one other thing you might consider: in the current firmware of the DS2000 series, it's very easy to 'keep' all of the expensive 'trial' options (triggering, decoding, etc) indefinitely. I don't know if that's true for the DS4000 series, but if I was considering getting a 4-channel scope, I'd try to find out from a current owner. That's quite a lot of money later down the line.
