Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Issue with PSU Model TPM-3005
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Issue with PSU Model TPM-3005 (Read 637 times)
nour
Frequent Contributor
Country:
calm down, it is just a smoked oPamP!
on:
June 17, 2020, 08:50:04 pm »
Datasheet:
https://www.twintex.com.tw/proimages/SZ_Datasheet/Twintex_Datasheet_DC_Power_Supply_TPM_201609.pdf
I have bought Power supply model #TPM-3005.
This model according to the datasheet(in the second page), can reach 36V/5A or 15V/10A!
After inspection I found the unit can only reach 5.1A max for all the voltage ranges, If I try and set the output current over 5A it doesn't accept the change!
I tried to disable any OVP and OCP but they were already disabled!
Can someone confirm if it is some bug in the software or it is something that I don't understand or may be there are some hidden configurations that I can't reach and set
Logged
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
nour
Country:
Re: Issue with PSU Model TPM-3005
Reply #1 on:
June 17, 2020, 10:15:28 pm »
I was able to fix the issue, there was a range switch (High-low) under some buttons but it was written with a fade and small text that I failed to notice at once, it is now working fine!
Last Edit: June 17, 2020, 10:58:37 pm by nour
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
