Author Topic: Testing Internet connection on same subnrt  (Read 2748 times)
Offline BocaDevTopic starter
« on: November 27, 2018, 09:51:53 pm »
I hope this is the correct sub-forum to post this question.
I received a communications controller in for repair. This controller is operated through its hardware Ethernet connector. My shop has a Comcast single IP address coming directly into my ATT router. I plugged in an Ethernet cable connecting it from the UUT to the back of my ATT router which has four Ethernet connectors, one of which is my computer plugged into. However, I am not able to establish a connection using my web browser. My web browser just times out. My computer is on IP address 192.168.1.100 and the UUT is at IP address 192.168.1.245.
Question.. Should I be able to do this on the same sub-net or do I need another router in here somewhere?
Thanks,
Alan
Offline capt bullshot
Re: Testing Internet connection on same subnrt
« Reply #1 on: November 27, 2018, 10:30:33 pm »
Of course, there are many pitfalls in many details - like the four ports of your router aren't a ethernet switch like everyone would expect, or the router issues subnets smaller than /24 as everyone would expect, or your computer is configured wrong in a subtle way, or the UUT is simply defective ...
But in general your setup looks like it should work, nothing else required.
Offline cdev
« Reply #2 on: November 27, 2018, 10:51:36 pm »
Try inserting Wireshark in there to see what exactly is being sent back and forth.
Depending on how your network is set up you may need to do network sniffing using port mirroring on a managed switch, a hub or whatever.
The Wireshark wiki has a good discussion of this.
« Last Edit: November 27, 2018, 10:54:22 pm by cdev »
Offline retiredcaps
« Reply #3 on: November 27, 2018, 11:34:15 pm »
First test is always to ping the device.  On your computer, do you get a ping response from 192.168.1.245?
Offline PaulAm
« Reply #4 on: November 27, 2018, 11:38:11 pm »
This stuff can drive you nuts.  Just today I had a voip box that would only allow initial configuration if plugged into a Windows box.
Does the device expect to be plugged into a local network or directly into a PC?  If you're using the cable that came with it, it might or might not be cross connected (if it's supposed to be directly connected to the PC and you're using the cable that came with it, it's probably a cross cable and might not work directly plugged into your router.  Some routers will recognize cross cables and handle things accordingly to further confuse things; some won't.)
You can get a cheap network hub, configure a static IP on your machine and plug the 2 devices into that and take ATT   out of the equation entirely.  The router might be providing DHCP addresses and the device might be picking that up.  Are you sure it's got a static IP?
You can also open a command window and use the ping command to see if your computer can see the device.  You might get more diagnostics that way.  You could also get nmap and use it to scan your network to see if the device is out there somewhere with an unexpected IP..
Offline cdev
« Reply #5 on: November 28, 2018, 01:23:06 am »
I don't know if anybody makes 'cheap network hubs' any more. So if you have any, save em. Don't let anybody throw them out, as they represent the easiest way to diagnose some kinds of IP problems.
Online bson
« Reply #6 on: November 28, 2018, 07:02:29 pm »
Indeed, this is why I still have an old 10baseTX half duplex collision domain hub.  This way when tracking down some bug like a bad checksum or truncated packet, I can simply look at the traffic in both directions with wireshark and see what is actually going on the wire.  Managed switches will do it too (I have several), but they require work to set up while this old hub just requires plugging in.  So unless I need 100M speed or VLAN, or some other feature I usually just reach for the slow old 10base HD hub!
Offline Brumby
« Reply #7 on: November 29, 2018, 03:45:04 am »
When I first delved into networking (on the small scale) I researched what hubs, switches and routers do - and I decided to go for switches instead of hubs.
I hadn't really thought about it before, but having a hub on hand for diagnostic purposes does make a lot of sense.  Pity I don't have one anywhere within my collection of stuff.
Offline LapTop006
« Reply #8 on: November 29, 2018, 09:31:15 am »
They can still be picked up cheap on eBay.
I have some taps which can be handy for debugging too.
Online grumpydoc
« Reply #9 on: November 29, 2018, 09:41:35 am »
How do you know the IP address of the unit is 192.168.1.245 - if that was the address in some other network but the unit uses DHCP to acquire an address it will probably pick up a different one in your network.
Unless the IP address is fixed, in which case it might help to know what subnet mask the unit is using - it should be 255.255.255.0 (but could be anything and certain combinations will prevent it chatting on your network).
Otherwise wireshark on a laptop connected via a hub to sniff the network packets going to and from the unit is a good suggestion.
« Last Edit: November 29, 2018, 09:43:13 am by grumpydoc »
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #10 on: November 29, 2018, 11:53:48 am »
If you're not sure of its address, the broadcast address for the network 192.168.1.0/24 is 192.168.1.255, ping that and everything in the network should respond. If you still can't see it, could also try with a ping to 255.255.255.255 although many/most things are configured to ignore pings to this address.
Offline LapTop006
« Reply #11 on: November 29, 2018, 12:05:39 pm »
Or use nmap to scan the subnet.
If it's dynamic and you have DHCP server logs, look at those.
Offline kaderud
« Reply #12 on: November 29, 2018, 12:06:45 pm »
One thing I would do is try to set the IP with the ARP-command from your computer, if you know the MAC-address of the device.
From a "cmd"-window:
arp -a
Displays the arp table.
arp -s 192.168.1.55 00-01-de-ad-be-ef
Adds a static entry to the arp table. Choose an IP in your IP-range, and replace the MAC-address (00-01..) with the device's address
« Reply #13 on: November 29, 2018, 07:19:56 pm »
Hi grumpy,
There is a hardware switch on the unit to place everything in default values. After doing so, that defaulted the IP to 192.168.1.245 with the mask at 255.255.255.1.
I have an old Netgear DS104 hub I can dig out from the closet (yes I have kept old hardware network stuff) and will hook up one of the ports with a cable between the output of my ATT router and the hub. Another port with a cable between the Hub and the UUT. Then another port connected to my laptop. I'll load Wireshark onto the laptop and exam what I see. Should turn out to be an interesting afternoon of network troubleshooting.
And a special thanks to everyone else with their suggestions and things to try. I will try every one.
Thanks,
Alan
« Last Edit: November 29, 2018, 07:23:52 pm by BocaDev »
  • Country: tr
« Reply #14 on: November 29, 2018, 07:38:30 pm »
And what's your IP? With that (funny) mask it can only communicate with even odd hosts: 192.168.1.1, 192.168.1.3, 192.168.1.5 etc etc. If I were you I would try to setup the IP of the PC manually to one of those (odd) IPs, with the funny mask (255.255.255.1) too, in network settings, then try to ping it.
« Last Edit: November 29, 2018, 08:57:21 pm by GeorgeOfTheJungle »
Online grumpydoc
« Reply #15 on: November 29, 2018, 08:39:46 pm »
Hi grumpy,
That's an invalid mask.
Masks have to be all '1's followed by all '0's so 255.255.255.0 is valid (11111111111111111111111100000000) as is 255.255.255.128 (11111111111111111111111110000000), 255.255.255.192  (11111111111111111111111111000000) and so-on.
And what's you IP? With that (funny) mask it can only communicate with even odd hosts: 192.168.1.1, 192.168.1.3, 192.168.1.5 etc etc. If I were you I would try to setup the IP of the PC manually to one of those (odd) IPs, with the funny mask (255.255.255.1) too, in network settings, then try to ping it.
I don't think it will even do that, if that really is the mask, it's just invalid - so might not want to talk to anything.
  • Country: tr
« Reply #16 on: November 29, 2018, 08:52:28 pm »
https://tools.ietf.org/html/rfc1219
Overview
   RFC-950 [2] specifies a procedure for subnetting Internet addresses
   using a bit-mask.  While RFC-950 allows the "ones" in the subnet mask
   to be non-contiguous, RFC-950 recommends that 1) they be contiguous,
   and 2) that they occupy the most significant bits of the "host" part
   of the internet address.
Offline JDubU
« Reply #17 on: November 29, 2018, 09:32:18 pm »
Here is an easy to use, freeware, network scanner that works well (Windows only):
http://www.advanced-ip-scanner.com/
Online grumpydoc
« Reply #18 on: November 29, 2018, 10:08:04 pm »
Overview
OK, well, you learn something new every day :)
However see https://tools.ietf.org/html/rfc1519
"An implementation following these rules should also be generalized, so that an arbitrary network number and mask are accepted for all routing destinations. The only outstanding constraint is that the mask must be left contiguous."
The odds that someone writing embedded firmware knew the bits don't have to be contiguous per 950 but not about the change in 1519 when CIDR was introduced and found a way to use that mask usefully do not seem high compared with the mask of 255.255.255.1 being misreported or plain wrong in the default settings.
« Last Edit: November 29, 2018, 10:40:27 pm by grumpydoc »
  • Country: tr
« Reply #19 on: November 29, 2018, 10:35:51 pm »
Yeah, that mask is either wrong or silly if you ask me :-) But sometimes they do these things (obscure, weird setups) on purpose.
« Reply #20 on: November 30, 2018, 01:47:10 am »
Sorry everyone, the mask is set to  255.255.255.0
My mistake. Too many numbers for my brain to keep track of.
Alan
« Reply #21 on: November 30, 2018, 02:11:34 am »
Thanks JDubU,
I just downloaded the advance IP scanner. Nice tool, even found attached network stuff I didn't know I had on my network. Anyway it did not find the UUT so I do have a problem. This unit has an internet activity LED on the front which is almost blinking continuously. Could be internet activity is coming in but nothing is being transmitted out.
Tomorrow I'll connect the hub and laptop as grumpy suggested. Will post my findings.
Thanks to everyone.
Alan
« Reply #22 on: December 01, 2018, 01:24:33 am »
I connected everything up today and have Wireshark on my laptop sniffing traffic. I can see several ARP request going out (who is 192.168.1.245) but no response from the UUT in response to the query's.
After doing some visual inspection, I discovered the Ethernet connector has some burn carbon deposits on a few of the gold wire connections within the RJ45. It possible a lightning strike within the area of the building had made its way onto the Ethernet cable. I'll change out the connector and hold my breath that the processor didn't get hit.
Thanks to all for your help,
Alan
