Author Topic: World's cheapest multimeter teardown  (Read 16830 times)
Offline rolycatTopic starter
Re: World's cheapest multimeter teardown
« Reply #25 on: March 26, 2015, 11:28:35 am »
A car battery?? Shorted?? They can push >60A! That'll fry anything including your best Fluke, never mind some $3 dollar Chinameter.
A shorted car battery can deliver over a thousand amps. Many car batteries have a cold cranking amps (CCA) rating of five hundred or more, and will exceed this by a factor of two or three in a dead short.
Offline McBryce
« Reply #26 on: March 26, 2015, 11:32:46 am »
Yes, I know. The 60A was more in reference to the highest (non-clamp) Ampmeter I've ever come across, not what the battery can actually achieve.
McBryce.
Offline meeder
« Reply #27 on: March 26, 2015, 11:37:16 am »
Several of the customers and friends I gave meters to ignored my warning and decided to measure amperage of their car battery by putting probes across or the like with expected result. In all cases it was the wires that went first. IMO those runs are more than adequate for 10a.
McBryce.
Years ago I measured the current draw on the battery in my 1991 Mk2 Golf diesel. First you have the +/- 10 seconds of glowing which draws around 50A and during starting the current draw peaked at over 400A.
Offline paulie
« Reply #28 on: March 26, 2015, 11:38:05 am »
As far as these or any meters are concerned the difference between 60a and 1000a is moot. It occurs to me the absence of a glass fuse may not be a problem at all. There is obviously a trace somewhere across those big pads and assuming it's thin enough should serve the purpose fine.
Offline danielpirozzi
  • Country: br
« Reply #29 on: May 13, 2020, 04:10:20 pm »
How the hell do you connect the battery on those springs?
Offline jeroen79
« Reply #30 on: May 13, 2020, 07:04:35 pm »
You can put the ends of the springs inside the battery's poles.
They're hollow inside.
The following users thanked this post: danielpirozzi
Offline Gandalf_Sr
« Reply #31 on: May 13, 2020, 11:33:31 pm »
How the hell do you justify exhuming a > 5 year old thread on a junk meter like this?
If at first you don't succeed, get a bigger hammer
