I am considering getting another generator that has floating outputs. I have found the following:
- Siglent SDG5162
Are you guys aware of any others that have floating outputs?
Since the earthed outputs of my function gen forced me to ground reference the circuit, I had to use a differential probe to do a meaningful evaluation of the device.
Floating FG outputs would also let me more easily add an AC offset to a DC supply, when I have the DC supply earth referenced to avoid common mode/mains noise (or want to float the entire circuit).
Well I've learnt this today from the forum, thanks.
(doesn't even know his own products. )
From the SDG5000 datasheet:
Isolation:
Connector shells for channel output(s),Sync,and Mod In are
connected together but isolated from the instrument’s
chassis,Maximum allowable voltage on isolated connector
shells is ±42Vpk
Seems they can supply up to 200 mA on the outputs too.
Sold one recently to a discerning buyer and now I know just why.
Checked a SDG1000 series for you and all BNCs are common with Mains Earth.
Yeah, thanks! I just noticed the SDG5000 can do up to 20vpp (high impedance), or 10v into 50 ohms. I don't think I've ever been able to get this high on my Rigol, but perhaps only certain frequencies can go this high. I guess this follows from ohm's law. 10v peak across 50 ohms = 200ma?
The main question I am asking in general is, how many people find the lack of floating inputs on a function gen to be a significant disadvantage?
The higher end generators do seem to have floating outputs (every HP/Aglient/Keysight ever, High-end Teks, Keithley, flagship Siglent). However, most people (at least on this forum) seem to use generators that do not have floating outputs. All of the Rigols have earthed outputs.
I have run into a few, and can think of many cases, where earthed outputs are an issue/disadvantage. Sometimes, these are related to the fact that scopes are earth referenced as well, which can be ameliorated with a diff probe. But some other situations *cannot* be addressed this way, hence the question.
