Not to be rude
I think you have to stop ...
and try to find someone beter experienced than you for windows iso files and recovery procedures
Your equipment may be very good, but you lack knowledge and experience, and restarting a new setup installation can happen
For the errors you have, you must learn
how to search the hardwares id's like the VID and PID of the errors you have in the properties panel of each error
You have reading to do, to help you understand what you are doing okay and are doing wrong
You could still use an older windows NT (Windows 2000) iso file to rebuild and restart you equipment, if it works okay, it will still be good
Between windows 2000 and windows XP on some equipment, you wont gain very much, not speed, not efficiency, But it will work.
Try the KO4BB iso file, restart a fresh setup and see if it work ...
I have seen your other answer on a other thread .....
https://www.eevblog.com/forum/repair/rohdeschwarz-fsp-hdd-defect/You have to be patient, it can take time to solve your problem, and you dont need to dump your equipmentI had problems like this in the past, it took me 2 weeks of search for some drivers, to restart an equipment
I had to mix drivers from many equipments to make it work ......
