Author Topic: DE-5000 IR to USB communication kit?  (Read 4271 times)
Offline CarpenterTopic starter
« on: December 21, 2017, 01:13:19 pm »
I try create IR to UART to USB converter for DE-5000 LCR meter
Any as
https://www.youtube.com/watch?v=0tOvNqYPlwY&feature=youtu.be
I use PL2303HXD USB to UART converter and NPN photo transistor L-53P3C Collector connect to RXD and Emiter to GND.
https://www.ebay.com/itm/1PCS-PL2303HXD-PL2303TA-6Pin-USB-to-RS232-TTLCable-Module-for-WIN-XP-WIN7-8-1/172426158988?hash=item282566638c:m:m3I00AwrdnTKYDkCHVGko0A
I thing if Transmit IR LED in DE-5000 shines is NPN Shitch ON and ground RXD.
I was expecting if I on DE-5000 press PC I in PC recieve any as https://www.eevblog.com/forum/testgear/decoding-der-ee-lcr-meter-de-5000-serial-bitstream/
 unfortunately I recieve only <0>  or 00 in hex view mode every 1sec.
In PC I use  https://sites.google.com/site/terminalbpp/
9600, 8,1,None
Any idea, where is the problem?
« Last Edit: December 21, 2017, 10:31:15 pm by Carpenter »
Offline thomasLE
Re: DE-5000 IR to USB communication kit?
« Reply #1 on: May 14, 2022, 03:47:00 pm »
In case anyone is still interested in building a custom IR-to-UART adapter...
I very recently created my own little blog where I offer everything needed in order to build your own adapter:
https://tltb.slur97.org/ir-to-usb-adapter-for-der-ee-de-5000-lcr-meter/
That includes the 3D models, a schematic and sourcecode - all free of charge, of course.
The following users thanked this post: ledtester, bc888, mankan
Offline GotZapped
« Reply #2 on: November 06, 2022, 10:50:39 am »
Hi ThomasLE,
I'm getting a 502 bad gateway, is the website down?
Offline thomasLE
« Reply #3 on: January 22, 2023, 05:11:22 pm »
Oh damn it - I didn't see your message until now :(
The website should be working again now.
Cheers!
The following users thanked this post: GotZapped
Offline mendip_discovery
« Reply #4 on: January 22, 2023, 05:57:33 pm »
This is perfect. I recently picked one of these up and I have used a sparkfun breakout rs232 style board and a sensor to recive the data. I found some Python script but it doesnt work currently so I was toying with getting that working. Of course I got distracted becuase a 3d printer turned up and I was just thinking about making a model for the sensor. This saves me a few hours.
I guess the only thing to do now is print it all up and get it working. I wonder if the unit can take input, I know its go no sensor for receiving signals but it looks like they had planned to do it just never did it.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online ledtester
« Reply #5 on: January 23, 2023, 03:22:53 am »
I added that page and the downloads to www.archive.org (aka the "Wayback Machine"):
http://web.archive.org/web/20230122180748/https://tltb.slur97.org/ir-to-usb-adapter-for-der-ee-de-5000-lcr-meter/
Offline mawyatt
« Reply #6 on: January 23, 2023, 05:53:40 pm »
Interesting project  :-+
The schematic shows U1B (unused 1/2 LM358) with the output grounded, this will cause excessive current draw in U1.
Should leave this output open instead of grounded as shown.
Best,
~Wyatt Labs by Mike~
Offline mankan
« Reply #7 on: January 28, 2024, 07:20:45 pm »
I've just built this but without the op amp and just reused the IR housing. Works great, thanks @thomasLE.
1993876-0
