Author Topic: Frequency stability of an HP3310A function generator  (Read 5823 times)
Offline KJDSTopic starter
    • my website holding page
« on: February 04, 2015, 05:26:19 pm »
I've just been asked what the stability is like for an old analogue HP3310A function generator that I've sold so thought I'd run some tests this evening.
I let it warm up, set it to 100kHz and it measured 100.454kHz.
I'll keep the thread updated to report how it drifts.
Re: Frequency stability of an HP3310A function generator
« Reply #1 on: February 04, 2015, 06:11:13 pm »
It's now at 100.366kHz
Offline Yago
« Reply #2 on: February 04, 2015, 06:36:45 pm »
How are you measuring it?
Just guessing here, but interested, I imagine a counter would have drift too.
« Reply #3 on: February 04, 2015, 06:42:22 pm »
I'm using a Keithley 2015THD, which has a not very accurate frequency reference, but it's likely to be way better than the HP3310A.
It's now at 100.365kHz and I'm off to find a better counter as I've just seen that the ancient HP box is far more stable than expected.
Offline Yago
« Reply #4 on: February 04, 2015, 06:51:06 pm »
Oh to even have the choice!
« Reply #5 on: February 04, 2015, 07:31:36 pm »
It's now reading 100.360 on the Keithley and 100.359 on a HP5334B
Offline Yago
« Reply #6 on: February 04, 2015, 08:10:01 pm »
That's just showing off now Kev ;)
« Reply #7 on: February 04, 2015, 08:27:24 pm »
They've both settled down to 100.355kHz
Given that the Keithley freq spec is only 0.01% and its not been calibrated in years it's doing well
« Reply #8 on: February 04, 2015, 09:17:54 pm »
100.349
I'm amazed at just how stable this is
Offline Yago
« Reply #9 on: February 04, 2015, 10:17:05 pm »
Tell you what, it's better than formula 1 this! :)  :-DD
« Reply #10 on: February 04, 2015, 11:03:42 pm »
100.352
Time for bed, so that's all folks.
Offline Yago
« Reply #11 on: February 04, 2015, 11:13:40 pm »
Cya later KJDS.
If you get time tomorrow, could you explain what we should look for when evaluating a gen like this?
What might be obvious, may not be so to the likes of me!
Cheers :)
Dave92F1
  • Guest
« Reply #12 on: February 08, 2015, 12:37:03 am »
I have a HP 3312A that is very _un_stable in frequency. Frequency drops about 20% over the course of two hours (even after warming up before starting), and doesn't really settle down even after 6 hours.  I wish I knew where to start looking for the problem...
Offline Paul Moir
« Reply #13 on: February 08, 2015, 02:21:40 am »
The 3312A just has a simple VCO controlling it's frequency.  Have a look at figure 7-5 in the manual, bottom or left hand side depending on which way you're looking at it.  Either it's one of the power supplies drifting (17, 14 and -14), the VCO input, something coming in from the modulation generator or one of the half-dozen components that make up the VCO.
Let me know if there's any specific measurements you want made.
« Last Edit: February 08, 2015, 03:25:44 am by Paul Moir »
