accuracy needed # digits, % ? Freq range min max?
2 way radios can be anywhere from low band SW, FM, VHF, or UHF bands, to name a few.
Jon
Frequency range 1.8 MHz to 500 MHz,
accuracy would like +/- .1 ppm, may not get that in this price range,
at least 9 digits on the counter.
Will be using it to align PLL/VCO's so it needs to be able to work with very low input voltages.
BG7TBL FA-2 spec’d to work down to -20bBm up to ~5GHz, and down to -50dBm up to 550MHz
CH1 Frequency Accuracy:
0.1s Gate Time: 0.001Hz@10M
1s Gate Time: 0.0001Hz@10M
10s Gate Time: 0.00001Hz@10M
CH1 Test Speed: 11 bits/second@10MHz
CH1 Power Test Range: -50dBm~+20dBm, 1M~550M@50 ohm
CH1 Power Test Accuracy: 0.5dB@10MHz
CH1 Connector Type: BNC
Introduction of CH2:
CH2 Frequency: 30MHz-6GHz
CH2 Input Impedance: 50 ohm
CH2 Power Accuracy: 1dB@2.45GHz
CH2 Frequency Accuracy:
0.1s Gate Time: 1Hz@1GHz
1s Gate Time: 0.01Hz@1GHz
10s Gate Time: 0.001Hz@1GHz
CH2 Input Power: -20dBm~+13dBm@0.5~5G
CH2 Connector Type: SMA
