Author Topic: Franky's Kelvin Clip kit.  (Read 23382 times)
Offline PedroDaGr8Topic starter
  • A sociable geek chemist
« on: December 04, 2015, 03:58:50 am »
As many of you know, Franky on here sells a DIY Kelvin clip kit. After some waffling I decided to try his most recent iteration of this kit and I must say I am thoroughly impressed. He has a winner of a kit for sure.
Contents of the kit:
  • 4x Banana plugs - 2x red, 2x black.
  • 1.2m of red 14AWG silicone wire
  • 1.2m of black 14AWG silicone wire
  • 2x updated Kelvin clips
  • Red and Black high quality heat shrink
I opted for the stackable banana plugs, though in hindsight I should have gone with the standard shrouded like he originally offered. The stackable plugs are great for individual cables but make no sense here.
The kelvin clips are made by ETA (Electronic Test Accesories) Taiwan and appear to be the same ones used by GWInstek for their LCR leads. These clips feel VERY nice, they are very solid and have a nice spring to hold them together. They grip the DUT nice and tight, without any problem of slipping. The wire connect can easily  detach from the body by the removal of a single screw. This makes it VERY easy to solder a very reliable connection without damaging the plastic body of the clip. The quality of the everything feels very good and comes together nice and tight when fully assembled.
Cutting the wire to length; each color was cut to two wires of 60cm length. The cable has a nice soft silicone shell and is VERY flexible.
Stripping off 5mm of the outer silicone jacket, I was really surprised at the number of strands in this wire. This high number of strands, combined with the soft silicone shell mean this is a very flexible wire which is easy to work with. Another thing to note, unlike most discount Chinese wire there is a solid amount of metal in the wire. I am unsure if the wire is tinned copper, tinned steel or aluminum. EDIT: It is very clearly tinned copper, see the end of the post for the evidence.
Stripping 5mm is basically perfect for inserting into the banana plugs.
Stripping 2-3mm off of the other end is perfect to fit into the connector to the Kelvin clip. The 14AWG wire is absolutely a perfect fit for these connectors. Sorry for the blurry photo, unfortunately, I didn't realize it was blurry until I started typing.
A quick comparison of cheap solder (red) versus Kester 44 (black). Both are supposedly 63/37 solder but it is clear they aren't even close to the same quality. I ended up removing the solder from the cheap one and applying fresh Kester 44.
Cutting a bit of heatshrink to cover the connector. This heatshrink really shrinks down, much more than most of the cheap heatshrink I have encountered. Additionally, when it shrinks down it gets a lot more firm, to the point it serves as a kind of strain relief.
Trimming the heatshrink back to the camfered edge to allow it to properly fit into kelvin adapter.
Putting it all together, large screws attach the connector to the kelvin clip.
The screw covers, a very nice touch. There is one for High Force, High Sense, Low Force and Low Sense.
Now the most important part, how does it work! Very well, my meter fluctuates between 0.1 and 0.4 mOhm when shorted. Additionally, a precision 294K resistor reads exactly 294.00K. I have NO clue why the images look so compressed, a recent update to my phone really messed up the digital camera it seems.
As I said before, I am REALLY damn happy with these. Especially when you consider the price! The whole kit was cheaper than just the clips on ebay. Also, shipping from Hong Kong only took one week, three days of which the package was sitting in New York waiting to be shipped to my region.
Edit: I dissolved a small spare portion of the wire in concentrated sulfuric acid so far only the outer tinning has dissolved. It appears to be copper underneath. So the wire is tinned copper.
« Last Edit: December 04, 2015, 09:18:13 pm by PedroDaGr8 »
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline BravoV
  • +++ ATH1
Re: Franky's Kelvin Clip kit.
« Reply #1 on: December 04, 2015, 04:17:07 am »
PedroDaGr8, thanks for sharing, great post !  :-+
At this stage when using heat shrink tube this, usually I cut and diced a hot melt glue gun stick into small pieces, about rice sized or other suitable sizes, and have them enough stuffed under the heat shrink tube before heating it.
Once heated, the glue inside the tube will melt and spread evenly squeezed by the shrinking tube's wall, forming a seamless, strong join from the tube to the thing inside, and sort of laminate it as well.
Also the layer of glue once formed and set, will serve as a good strain relief better than the tube alone, particularly near the end of the tube and cable. Sometimes all you need is just to trim the excess glue that oozed out, but its no biggie.
« Last Edit: December 04, 2015, 04:19:22 am by BravoV »
Offline BravoV
  • +++ ATH1
« Reply #2 on: December 04, 2015, 04:47:24 am »
I believe the same wires supplied as my purchased of other type of kelvin clips from Franky (Photo) , I believe the wires are tinned copper, photo attached below.
« Reply #3 on: December 04, 2015, 04:50:28 am »
Yep, I just updated my post to reflect that right as you were posting. I dissolved the tin with sulfuric acid and they appear to be tinned copper. I included an image at the end of the post. Hopefully, by tomorrow I will see the characteristic blue green color of copper sulfate.
Sent from my LG-ls990 using Tapatalk
« Last Edit: December 04, 2015, 04:55:56 am by PedroDaGr8 »
Offline edpalmer42
« Reply #4 on: December 04, 2015, 05:26:16 am »
One nice thing about Kelvin connections is that the wires aren't very important.  Any voltage drop in the 'force' wires is irrelevant because those wires aren't in the measurement circuit.  There isn't any significant voltage drop in the 'sense' wires because the sense inputs are high impedance.  As long as the wires are reasonable, both electrically and mechanically, you're good to go.
It almost seems a shame to waste nice 14 guage silicone cables on that.  They'd make great test leads for current measurements on a DMM.
Ed
Offline Vgkid
« Reply #5 on: December 04, 2015, 05:31:15 am »
Can you post some pics if the actual clips.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #6 on: December 04, 2015, 05:58:50 am »
A very nice job and a brilliantly well documented thread....thank you.... :-+
If you get a chance could you perform a comparison measurement with both 2 and 4 wire using the same setup and equipment, also a link to the product and 99 cent hobbies might be handy for those coming directly from Google.
Low ohms and kind regards.... :)
Offline iloveelectronics
  • Country: hk
« Reply #7 on: December 04, 2015, 06:29:29 am »
Here are a few pics of the actual Kelvin clips for those interested (click to enlarge):
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline Vgkid
« Reply #8 on: December 04, 2015, 06:37:48 am »
Wow, those do look really nice.
Offline JacquesBBB
« Reply #9 on: December 04, 2015, 07:35:37 am »
Can you provide the link to this kit ?
Offline ivaylo
« Reply #10 on: December 04, 2015, 08:16:49 am »
Yeah, I'm not seeing it in Franky's store either...
Offline Shock
« Reply #11 on: December 04, 2015, 09:40:19 am »
If you get a chance could you perform a comparison measurement with both 2 and 4 wire using the same setup and equipment.
I only see this test as meaningful if you are making a comparison against another set of leads of an equal length. Assuming the wire is decent quality (again a comparative measurement needs to be made) then the contact resistance of the banana plugs and the clip would seem more important to me.
  • Country: hk
« Reply #12 on: December 04, 2015, 10:05:01 am »
Thanks for all the interest folks. I haven't actually stocked these yet so they are not in my eBay store. I only have one pair left at the moment and someone already PM'ed me so looks like I'm already out. Will try to stock some but problem is I will be going away on a holiday next week until after Xmas, so I'm afraid it will be a while before I can sell these. My apologies for the wait :(
Offline nidlaX
« Reply #13 on: December 04, 2015, 10:33:56 am »
Doh! I wish you'd stocked these earlier, I would've gotten some with that big order I'd placed. Some of it was actually prepping to build a set of kelvin test leads, but you didn't sell the clips yourself at the time.
Nice review Pedro! I've been meaning to post a review of a bunch of odds and ends I purchased from Franky, most of it is quality stuff!
Offline Deathwish
  • Country: wales
« Reply #14 on: December 04, 2015, 10:34:49 am »
I have enough dmm leads and probes that all i need is the clip on ends to put on those. or its back to using wooden clothes pegs with wires attached
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
« Reply #15 on: December 04, 2015, 01:56:46 pm »
Ed
The benefit is they fit PERFECTLY into the wire connectors. The silicone shell is a nice solid fit in the outer body of the connector, while the stripped wire is the perfect fit in the inner solder cup portion. While what you say is true, the mechanical benefits of this fit are very evident in how the end product feels. So while there is not an electrical benefit per se, there is VERY much a mechanical and tactile one.
Also, I did get another 2 meters of each color, plus the necessary stackable banana plugs, to make some patch cables of my own. I ended up making two pairs of 0.5m and one pair of 1m length cables. They feel perfect and make life much easier when testing multiple meters at once.
Franky has often said that he has more stuff available than he lists in his store. Some stuff I guess is stuff he can't get a suitable supply for listing, other stuff is evaluation items, etc. If you are ever looking for something specific it might be worth your time to contact him to see if he has something which will work or can get something easily. Obviously, not everything will sell well and being in business he tends to stock the stuff that will make him the most profit.
If I had known this, I would have waited to post my review. Maybe you can setup a pre-order setup, where people purchase and you fulfill when you get back (just being clear that you will be on holiday for the next couple of weeks). I think most of us here known you and trust you well enough for that.
Thanks Nidla! Yeah, I ordered some extra cable and banana plugs to make my own cables and some of the sprung hook grabbers. Everything is top notch quality, the hooks grip tight and are made of a very nice plastic. They do not feel cheap at all. Light years beyond some of the cheap chinese crap that I have encountered.
« Last Edit: December 04, 2015, 02:04:02 pm by PedroDaGr8 »
Offline free_electron
    • SiliconValleyGarage
« Reply #16 on: December 04, 2015, 05:49:19 pm »
ooooh . VERY nice indeed !  put on my wishlist ...
Offline H.O
« Reply #17 on: December 04, 2015, 06:10:57 pm »
Yes, I bought a cheap set on EBAY (ie not from Franky) some time ago and these look much nicer than the ones I got.
Hoping for an update to this thread if/when they're available!
« Reply #18 on: December 04, 2015, 06:30:39 pm »
Nice, and luckily I was able to order something else from Frankie, which was shipped and is already nearly at it's destination. Not for me, but the service from Frankie is always good, too bad he no longer deals with SA because of SAPO and the poor delivery times they have for inbound mail.
Suggestion is if Frankie can source some adhesive lined heatshrink in red and black, to supply in these kits, which will make the strain relief much better by supporting the solid soldered wire end. I have used clear ones from RS in the past, and they are very high shrink ratio, and a very good seal especially in wet locations ( I used them in seawater for a long time with no corrosion problem at those joins). The Tyco solderform shrinks are also very good, if not for the cost being so high, even for Aerospace graded parts. Still have a few in a bag for use when needed.
« Reply #19 on: December 04, 2015, 09:00:44 pm »
Quick update: I added some photos of the bare clips themselves to the original post. I thought I had lost these photos when I updated my phone but I found them in a backup. They clearly show the quality of the clips themselves and how they are assembled.
Offline vindoline
« Reply #20 on: December 05, 2015, 02:05:09 am »
 :-+ for nice use of H2SO4!
« Reply #21 on: December 05, 2015, 03:21:52 am »
the only thing that worries me a bit is the usage of dissimilar metals between the clip and the wire termination ( where the screw goes in )
that may give thermocouple effects..
« Reply #22 on: December 05, 2015, 03:45:59 am »
Honestly, I don't know enough about this but if there are any tests I can do with an HP 34401A and these leads, then let me know.
Offline joeqsmith
« Reply #23 on: December 05, 2015, 06:33:44 am »
"Very well, my meter fluctuates between 0.1 and 0.4 mOhm when shorted. "
That's impressive.  I think mine moves a lot more than that.  I tried to make some low resistance measurements with one some time ago without success.    It's been a long time but I thought they did not offer a oven as an option and was not chopped?     :-//
How much does your ambient temperature change?
The kit looks nice.   Would you gain anything using shielded cable?
Offline Shock
« Reply #24 on: December 05, 2015, 12:22:07 pm »
Less EMF, also depends on how the instrument takes the measurement and averaging.
