Of course Tony_G, all of that makes perfect sense in light of the new situation. It’s always very interesting to observe the differences between units, with each one having a different story to tell. Here’s what I’ve observed so far, with “unit A” being the original unit, and “unit B” being the new unit:
The two case designs are different, with unit B more closely corresponding to the ARTEK manual drawings. Unit A has better component cosmetics all around, so combining them is going to improve things.
Unit A’s filter caps are in pretty good shape, unit B’s, not so much. They seem to have seen some heat in the past, though they don’t seem to run hot with a quick test. The listed 13,000 uF cap in B has been replaced with a 24,000 uF unit, which doesn’t test great, …ok, but not great. My current thinking is to just swap cap sets.
The F1 fuse in unit B appears to be original, but is 5A @ 125V, not the listed 4A.
I’m sure that the attenuator grommets in unit B are wearing out, as they do, but I’m going to let that Dog sleep until I can’t.
I will be swapping out the faceplate/keyboard assembly from unit A onto unit B. along with feet and handle hardware.
Quick aside, and maybe I should post this on the HP forum, but does anyone know what the “warm gray” color numbers are for this era of HP gear? They used it a lot back in the day (80’s) and I assume it comes from the Government Standard 595 colors, but don’t know. I’d like to source some touch up paint in that color. The “Beige” color of the same era might also come in handy.
Anyway, that’s just a little “color” on what’s going on. Always appreciate any feedback.
Later,
JRH
