Author Topic: Fnirsi -TC3  (Read 12905 times)
Offline botvink
  • Country: sz
Re: Fnirsi -TC3
« Reply #25 on: January 23, 2024, 10:01:04 am »
I made the mistake of buying one last year, the oscilloscope function was measuring 0.5V offset at idle and different voltages in normal measurements, I sent Fnirsi company a Whatsapp email message on every channel and waited for them to solve it with the firmware, they further corrupted the function of correcting a simple voltage offset with another clean voltage. It would be great if they added it or developed it themselves. After pages and pages of messages, I was left unresolved. The answer was that you bought this product from another Aliexpress seller, not from us. But I said the product is your product, but it would be more useful if I talked to the wall.
I mean, it's a product with potential, but since they don't have any engineering development skills, I don't understand why they can't fix the problems of the actual product while spending so much budget on marketing.
Offline slavoy
Re: Fnirsi -TC3
« Reply #26 on: January 23, 2024, 04:36:33 pm »
FNIRSI policy will be like this: New cool looking TC-4 with minor updates after release, no care for older devices  :-// If it doesn't work from the start, you are on you own.
Offline KungFuJosh
  • TEAS is real.
Re: Fnirsi -TC3
« Reply #27 on: January 23, 2024, 07:50:53 pm »
Cool opinion. Of course, it's still supported for now, and has a firmware download available on their website: https://www.fnirsi.com.cn/download/digit
I don't expect a $50 toy to compete in support levels with $5000 scopes. Nobody should. 🤷
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline cgershon
  • Country: il
Re: Fnirsi -TC3
« Reply #28 on: March 05, 2024, 05:30:12 pm »
You must change also U10 ...
Offline cgershon
  • Country: il
Re: Fnirsi -TC3
« Reply #29 on: March 05, 2024, 05:34:04 pm »
Offline eevbstedt
Re: Fnirsi -TC3
« Reply #30 on: April 20, 2024, 05:05:02 pm »
Thanks! That's good to know. I think they'll fix the fixable bugs eventually. I turned off the logo in there, now it starts up faster lol.
Has anyone found a newer firmware other than v0.30 ?
Offline KungFuJosh
  • TEAS is real.
Re: Fnirsi -TC3
« Reply #31 on: April 20, 2024, 05:33:57 pm »
That's still the latest version on their website. I don't know where else you would find firmware.
Offline axantas
Re: Fnirsi -TC3
« Reply #32 on: April 20, 2024, 08:31:29 pm »
Ask Finirsi for assistance on their WhatsApp Grup. They are quite helpful.
Offline MWBSYS
Re: Fnirsi -TC3
« Reply #33 on: June 14, 2024, 03:21:52 pm »
Can you tell me whether the repair was ultimately successful and what part U6 is?
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
Re: Fnirsi -TC3
« Reply #34 on: June 14, 2024, 06:43:22 pm »
FNIRSI got a report from me about bullshit results at testing germanium diodes, germanium transistors and some hfe comparations to the TC1 what was much better in accuracy.
So I hope they have done a large update there.
Offline tony359
Re: Fnirsi -TC3
« Reply #35 on: August 02, 2024, 01:49:46 pm »
I've got one today - and I am going to show it on my YT channel.
Not having a proper LCR tester to compare it, I compared it with a very cheap component tester I've been using for years, bought "bare PCB" on Ebay. The ESR readings are completely different between the two so I started looking online for someone who might have done a comparison with a proper tool and as you said, I could not find any. But I found this thread and another one mentioning the same thing. Sigh.
So not having a proper tool to compare it with, it's difficult to say. But doesn't look good.
Offline Phil1977
Re: Fnirsi -TC3
« Reply #36 on: August 02, 2024, 02:40:58 pm »
ESR without further specification is as asking how fast a car accelerates and answering "8 seconds". 8 seconds for what? 0-100km/h, 0-60mi/h, quartermile, ...???
You may use these functions to compare components against each other with the same tester. But not really as an absolute measure that´s expected to be the same between different instruments.
You can be quite happy if the capacity measures the same in a +/- 10% range.
Every time you think you designed something foolproof, the universe catches up and designs a greater fool.
Offline KungFuJosh
  • TEAS is real.
Re: Fnirsi -TC3
« Reply #37 on: August 02, 2024, 03:34:16 pm »
If you want to know if the ESR measurement works, and you have no serious LCR to compare to, check the datasheets for each capacitor. If it matches every datasheet, it's probably okay. If it's not even close, then ignore the ESR claims on the device.
Offline tony359
Re: Fnirsi -TC3
« Reply #38 on: August 02, 2024, 10:03:28 pm »
Oh yes I am not expecting the device to be super-accurate.
But I tested some bad capacitors on my old tester and one read 60 Ohm ESR. The FNIRSI read 0.6Ohm. I mean, that's a 100 factor in there :)
Oh excellent idea thanks. I normally use Panasonic caps - from Mouser/Digikey - so I should be able to do a good comparison.
Offline watchmaker
  • Self Study in EE
    • Precision Timepiece Restoration and Service
Re: Fnirsi -TC3
« Reply #39 on: August 03, 2024, 01:08:30 am »
As my daughter sez, I am easily distracted by shiny new objects.  So I saw this on "super sale" for $25 and thought WTH.
on.  I now have an inkling how he felt.
Mainly, I am truly amazed at what is done today compared to the days of the Simpson 260, RCA VoltOhmyst and Dumont scopes.  I wonder if most people truly understand how far we have come.  Had a friend who qualified flying biplanes off the Langley and retired as a commander of a jet squadr
OK, my Shannon Tweezers have nothing to fear (C and ESR way of the TC3 is way off as others noted), nor are my scope and AWG threatened.  It seems the ESR comes closest to the tweezers if the tweezers are set to 1KHz.  But I would just use the tweezers for IDing caps anyway.
The device ID and zener tester are useful, and the continuity tester is probably its best feature (near instantaneous). At least the voltmeter is within 5mV of my bench meters.  Resistance is also off (5% low).
The wave generator may be useful for someone just starting out, but I am not sure how.  I suppose the single channel scope has some use.
But, it will replace my old $12 device ID thingy and may well be worth the premium (double the $12).  The lack of reverse polarity protection is an issue though.
But for $50 or $100; that is not shiny new toy impulse pricing for me.  I would continue to save my pennies for the Analog Discovery 2 or 3.
« Last Edit: August 03, 2024, 08:32:20 am by watchmaker »
Regards,
Dewey
