Author Topic: Unlocking Siglent SDS1104X-E, step by step  (Read 217315 times)
0 Members and 14 Guests are viewing this topic.
Offline guho
Re: Unlocking Siglent SDS1104X-E, step by step
« Reply #500 on: April 02, 2024, 05:38:25 pm »
Is it safe to update the 4-channel SDS1xx4X-E to version 6.1.37R10 or will I lose unlocked features? Same question about OS: SDS1xx4X-E Operating System -V3. Is OS V3 required for 6.1.37R10? Many thanks in advance for answers.
« Last Edit: April 02, 2024, 05:40:31 pm by guho »
Offline BillyO
« Reply #501 on: April 02, 2024, 06:34:28 pm »
Since the features were unlocked with valid license keys, the version update should not have any detrimental effect on them.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline moerdijk
« Reply #502 on: June 02, 2024, 06:59:55 pm »
Yes it still does.
Make sure to put `SDS1000X-E` as the model and not `SDS1004X-E` like i did at first  |O
Offline LogicalDave
« Reply #503 on: June 22, 2024, 03:04:26 pm »
I know this was an old question from @bffargo, but it's a good one:
1) Some old posts / videos show the -3db drop at around 130 MHz when using original firmware at locked 100MHz bandwidth.  Once you unlock it to 200, does it still have the -3db drop there or does it get extended? what is the drop @ 200? I couldn't find a definitive post on a hacked one.
I expanded the bandwidth of my SDS1104X-E to 200MHz and used it to measure the output of an IFR 2025 RF signal generator at 0dBm. I compared it with two other scopes: Tek TDS3K and Owon SDS8202.
At 100MHz the signal was flat and there was still no significant drop off at 130MHz.
At 200MHz:
  • Siglent: -1.15dB
  • Owon: -0.343dB
  • Tek: +0.157dB
Note that I didn't have 50R through terminators for the Siglent or Owon so those were measured using a BNC-T and 50R terminator.  The Tek scope had internal 50R termination settings.  I've ordered a BNC through terminator and will re-test with it and a 6dB pad and report if the results are significantly different.
As others have found, the 3dB point on my hacked SDS1104X-E was between 230MHz and 235MHz, so the hack definitely works.
I'd be curious if anyone has a real (not hacked) SDS1204X-E and can compare Vpp at 200MHz.
« Last Edit: June 22, 2024, 03:07:11 pm by LogicalDave »
Offline BillyO
« Reply #504 on: June 22, 2024, 03:26:09 pm »
At 200MHz:
  • Siglent: -1.15dB
  • Owon: -0.343dB
  • Tek: +0.157dB
I don't think the through terminator is going to make a significant difference.  Which version of the Tek was it?  They come in 100, 300 and 500MHz.  Even old and used they are 3x the price of the Siglent.
