TheDefpom, The Electrician and 3 Guests are viewing this topic.
Quote from: mawyatt on Yesterday at 12:36:10 amWRT to the IM3570 measurements from Josh, we've including a plot of a frequency sweepA great point, as always. The cap I was using is an electrolytic. Here's what that looks like across the range. You can see where there's a small section of overlap.
Can the IM3570 show Z and R in Log/Decade format vs. Log/Decade Frequency? This should show Z and R in more detail around the resonate frequency area.
Attached are the 100kHz and 118kHz screenshots, note that they were taken at different room temperatures, hence the change.At 1kHz the ST42 makes sense and Z/ESR agree, but at 10kHz Z makes sense, and ESR is too low.
