Author Topic: Fnirsi has a new tester, the LCR-P1  (Read 784 times)
Online RAPoTopic starter
« on: August 26, 2024, 01:55:29 pm »
This time with an SMD-fixture.
I have one on order and will report back as it arrives.
Offline mawyatt
Re: Fnirsi has a new tester, the LCR-P1
« Reply #1 on: August 26, 2024, 02:27:39 pm »
Wouldn't put much faith in this device since they can't even get the polarity of the transistor correct :palm:
Best,
« Last Edit: August 26, 2024, 02:31:00 pm by mawyatt »
~Wyatt Labs by Mike~
« Reply #2 on: August 26, 2024, 02:32:54 pm »
I'll see an opportunity: it turns pnp into npn. :-+
Offline mawyatt
« Reply #3 on: August 26, 2024, 02:39:51 pm »
It's an Inverted NPN, or they prefer Electron Flow  ;)
Best,
« Last Edit: August 26, 2024, 02:44:03 pm by mawyatt »
The following users thanked this post: RAPo
« Reply #4 on: August 29, 2024, 05:45:44 pm »
Fnirsi mailed: the image will be corrected.
It was due to ...drum roll ... a mirror effect. That got me puzzled for 5 seconds ;-)
Best,
Offline Andrey_Ak
  • Country: kz
« Reply #5 on: September 08, 2024, 05:26:37 am »
Hello! FNIRSI DSO TS3 and TS2 do not measure ESR correctly or do not know how to measure it at all!   Fnirsi LCR P1 - Does it know how to measure ESR and does it measure correctly?
So the FNIRSI DSO TS3 and TS2 testers are completely inoperable, and are just toys.  I would like to buy a normal tester, in a good case, which measures the ESR correctly, and not randomly like the TS3.
Will the new tester have the opportunity to flash new firmware, and will you work on improving the firmware, or will you also drop the new tester like TS2 and TS3?
Online KungFuJosh
  • TEAS is real.
« Reply #6 on: September 08, 2024, 04:32:25 pm »
Every single one of these are decent at detecting transistors, and terrible at LCR function. If you want an LCR, you should buy a real LCR.
Shannon ST42 tweezers, DER-EE DE5000, etc. Will give you real LCR readings. People expecting $30 toys to do everything are being unrealistic.
Offline Andrey_Ak
  • Country: kz
« Reply #7 on: September 08, 2024, 05:04:01 pm »
I have professional devices, DerEE DE-5000, RuoShui 4091C, Miron m63 v3.4a
I need a transistor tester, but since it has an ESR measurement mode, it should work.
For example, the simplest transistor tester MTester LCR-T4 shows ESR measurements relatively correctly.
I want the device in a finished form, in a beautiful case.
But the previous FNIRSI DSO-TS3 device measures the ESR completely incorrectly, it simply substitutes the
programmed values for different capacitances, and the presence of an "oscilloscope" in it makes this TS3 just a child's toy.
« Reply #8 on: September 08, 2024, 05:16:31 pm »
In that case, splash out some money and buy the Atlas ESR Gold.
Offline Andrey_Ak
  • Country: kz
« Reply #9 on: September 08, 2024, 05:22:30 pm »
I wrote that I need a transistor tester in a beautiful case.
The Miron M63 v3.4a is a more professional and more convenient device than the Atlas ESR Gold.
« Reply #10 on: September 08, 2024, 05:25:53 pm »
Sorry, I thought you wanted a tester with the correct ESR in a nice case.
It seems you have found what you want.
Offline Andrey_Ak
  • Country: kz
« Reply #11 on: September 08, 2024, 05:56:02 pm »
Yes, I need a transistor tester in a nice case. I will not measure the ESR with it.
But since this transistor tester can measure ESR, then I would like it to measure more or less correctly.
The simplest testers like MTester LCR-T4 can measure correctly.
So I wanted to know if this LCR-P1 measures correctly, or shows nonsense like the previous two versions of FNIRSI TS2 and TS3.
