Author Topic: FNIRSI 1C15 Handheld Scope  (Read 3805 times)
Offline EEVblogTopic starter
« on: February 16, 2021, 11:02:21 am »
An update to the 5012H, sent into the mailbag.
Teardown
Claims 110MHz, but again only a dual 100Msps converter the MXT2088
Re: FNIRSI 1C15 Handheld Scope
« Reply #1 on: February 16, 2021, 11:31:53 am »
Any better than 50mV/div sensitivity on this one ?
Online Fungus
« Reply #2 on: February 16, 2021, 11:59:21 am »
Overclocked?
Online ataradov
    • Personal site
« Reply #3 on: February 16, 2021, 05:33:07 pm »
They switched to ST micro instead of GD. So they are probably not overclocking it. Probably don't need to with external memory.
But generally, I would assume it has the same crap performance as the old one.
Alex
« Reply #4 on: February 16, 2021, 10:45:40 pm »
20mV/div lowest, have not tested it
« Reply #5 on: February 16, 2021, 10:46:51 pm »
Seems to. Still wobbly performance on anythign over like 20MHz or so. They are equivalent time sampling again  :palm:
Offline Aiy
« Reply #6 on: February 17, 2021, 06:43:51 pm »
In the video I think Dave had the trigger point (T) all the way to the right in the display when doing the high frequency measurement ( see video at 38.53 https://youtu.be/QKdLP1cP3Dg?t=2333 ), not sure if that was on purpose but it could explain the jittery-buggery going on. I'm guessing this device does not have a good base oscillator.
Best regards
