Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 823675 times)
Offline Evi
  • Country: ru
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #2450 on: Yesterday at 02:53:48 pm »
Just upgraded from v0.021g to v0.025m.
I have to state out, that everything now satisfied me.
Offline Felipe Lacerda
  • Country: br
« Reply #2451 on: Yesterday at 03:10:08 pm »
Whats this square for at the bottom of our 1013D  ?
The yellow line represents the entire acquired signal sample, and the square represents the section of the signal that is being displayed.
Offline pcprogrammer
« Reply #2452 on: Yesterday at 03:43:41 pm »
That is to show where in the sample memory you are looking at the samples. Nice little feature Atlan came up with. (Stole from other scope makers  :-DD )
Offline Atlan
  • Country: sk
« Reply #2453 on: Yesterday at 03:55:49 pm »
The indicator is mainly there for this gadget.
Because the original fnirsi firmware is severely limited.
The ACQ menu allows you to change the sampling frequency, this displaying a larger part of the progress of, for example, an I2C signal.
The oscilloscope has a memory of 3000 samples in the FPGA. This indicator shows where you are in the sample memory. (I would like to complete it - it does not allow movement by dragging the finger in the lower part and does not match the size)
And I still failed to implement long memory - to use 3000 samples, although the stupid FPGA design can only use 1500, ie from the center where the trigger is. :(
mini update v0.025p change memory slider, move rtc text in menu
« Last Edit: Yesterday at 06:24:48 pm by Atlan »
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
