Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 800321 times)
kaa and 20 Guests are viewing this topic.
Offline pcprogrammer
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #2025 on: February 24, 2024, 05:59:52 pm »
Thanks Peter. I already had gnu-arm-none-eabi  of course or nothing would have compiled. Lots of modules compiled correctly just not the last. Doesn't the makefile determine the order of the build? The code already makes pretty good sense to me but the build process is not working due the error above...
There is no overall make file. Each project has its own make file. What is integrated in them is the copying of the output to the other project directory and the merging them together to make the needed single binary to load on the SD card.
With "project" I mean a set of .c and .h files that contain a single main function and other functions needed to make the compiled binary.
The only make file I see is the one in the directory with the .c and .h files. That isn't the make file for the "project"?
Look in the nbproject directory in each project. There are the dedicated .mk files for the different configurations like debug and release. These are called from the main make file.
« Reply #2026 on: February 24, 2024, 06:02:32 pm »
PC: How is a specific PIN set in the processor, should it be input or output? Are the pins open collector?
If I want to set the MISO-61-PC2 pin as an input, how do I do it?
Or is it already set somewhere as an output?
How can I load it? (if pin==1) through which register?
I am considering connecting a pull-up resistor and an optocell there. It would serve as an external trigger (max 12V input). The BNC should be placed next to the power switch, at least for the glass version...
Sometimes it's good to have it. For example, when debugging uP, ext trigger, it is possible to see a specific part of the process, e.g. i2c code
Take a look at the user manual. Chapter 3.7 tells you everything you need to know.
Offline dfw_ee
« Reply #2027 on: February 24, 2024, 08:55:21 pm »
Did you see the picture? you have the complete path to the MAKEfile there.
Yes, the problem was never the Makefile. I did "make all" and that caused the problem. I don't know why I didn't just type make. Had been up way too long I guess  ;D Anyway, I am able to build everything now including the TPx versions
Thanks for all the help Atlan and Peter!
Offline dfw_ee
« Reply #2028 on: February 25, 2024, 06:50:34 am »
Finally the scope touch screen is working normally again. I used the TP1 executable and a hex editor to change the 0x8047 register to a 0xBD to reverse the axis. Ran the executable and all is good. I had tried setting values in registers 0xB7 to 0x80C4 with 0x8047 set to FD but could not get it to work completely right. The axis were correct but the touch points were about 1 square below what was printed.
Thanks Atlan for writing the various TP programs! I am able to build these but when loaded on the SDCard it isn't loaded but boots from the internal flash. This is what happened with your orginal TP4 version. Any idea what is causing this? I got around it by just hacking the TP1 file with a hex editor.
Thanks Peter for all the help and pointing me to the display programming manual.
« Reply #2029 on: February 25, 2024, 07:25:56 am »
Sounds like the boot loader is missing. The first 32 bytes of sector 16 on the SD card need to be the eGON boot header for the F1C100s to start loading the actual boot loader into the internal SRAM. The boot loader is then executed and this will enable the DRAM and load the actual program.
The bytes need to be like shown below.
06 00 00 EA 65 47 4F 4E 2E 42 54 30 F7 6F 69 AE 00 3A 00 00 53 50 4C 02 00 00 00 00 00 00 00 00
Offline Atlan
  • Country: sk
« Reply #2030 on: February 25, 2024, 08:18:34 am »
 download again, fixed
https://github.com/Atlan4/Fnirsi1013D/blob/main/TP%20write%20config%20v0.023x.zip
tp3 and tp4 work, TP4 contains all 4 data fields
firmware is:  fnirsi_1013d.bin
« Last Edit: February 25, 2024, 11:53:41 am by Atlan »
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
Offline dfw_ee
« Reply #2031 on: February 25, 2024, 07:08:55 pm »
Thanks!
Offline Atlan
  • Country: sk
« Reply #2032 on: February 25, 2024, 09:38:51 pm »
Test firmware for Tokar.
Add DC offset auto settings for CH1. Try CH1.
« Last Edit: February 25, 2024, 10:33:22 pm by Atlan »
The following users thanked this post: tokar
Offline dfw_ee
« Reply #2033 on: February 26, 2024, 02:04:10 am »
There is still something I am missing. What is the process that converts from the fnirsi_1013d_scope.bin which is 258,048 bytes to the fnirsi_1013d.bin 0.023 TP1 write.txt which is 297,032 bytes and has the boot loader. The extra bytes I'm assuming is the boot loader but I don't know the process for getting there. Is it something post to the build or is it a make target or something else? The .txt versions boot from the sdcard and the .bin do not. My builds only produce the .bin that is the smaller size. These 2 versions were in the zip file you sent before I did any builds.
Sorry I haven't figured this out...
« Last Edit: February 26, 2024, 02:06:24 am by dfw_ee »
Offline Atlan
  • Country: sk
« Reply #2034 on: February 26, 2024, 06:32:47 am »
Last uploaded TPczip. In it, all versions of bin, run alternative firmware
Do not change the names of the files in the working folder!!!
mksunxi and flashfilepacker and fnirsi_1013d_scope.elf They must be set in properties as executable.
2037050-0
If the names are correct, the program that is there will combine all 3 bins from the projects into one. fnirsi_1013d.bin
« Last Edit: February 26, 2024, 06:56:18 am by Atlan »
« Reply #2035 on: February 26, 2024, 07:52:06 am »
mksunxi is used to fix the checksum in the program header the boot loader uses. This is a tool written by the sunxi group.
flashfilepacker is the one who takes the separate bin files and sticks them together in the final bin file. This is a tool I wrote myself. Source can be found here.
Offline Atlan
  • Country: sk
« Reply #2036 on: February 26, 2024, 09:58:00 am »
Small fixes, adding offset to both channels. Bit of a miscalculation of the shift. I will finish later. Firmware v0.024c
Modified instructions for the oscilloscope. FNIRSI 1013D  alternative firmware v0.024c ANG v1.doc
« Last Edit: February 27, 2024, 07:12:09 am by Atlan »
The following users thanked this post: tokar, facekim
Offline dfw_ee
« Reply #2037 on: February 26, 2024, 02:30:32 pm »
(Attachment Link)
I have used the latest TPczip. I extracted the files and made no changes whatsoever. I did a make in the TP1 directory and it built a .bin file that replaced the .bin file that was already in your directory. It did not replace the combined .txt file. It is the .txt files that actually work. Here is the last part of the build process which seems to match the picture you sent the other day:
arm-none-eabi-objcopy -O binary dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.elf dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin
./mksunxi dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin
bootloader size= 3f000
The bootloader head has been fixed
./flashfilepacker -o dist/Debug/GNU_ARM-Linux/fnirsi_1013d.bin -i dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin -l 0x9800
From above it looks like only the .bin file is the output and this file does not load on the sdcard. The .txt file that pre-existed in your directory does load. The pre-existing .bin file does not. It behaves the same as the new bin files that I build. No names have been changed nor anything else after the unzipping. How did the .txt files come about? It isn't a simple renaming of the .bin file.
« Reply #2038 on: February 26, 2024, 02:59:19 pm »
The output file to look for is fnirsi_1013d.bin
the command "./flashfilepacker -o dist/Debug/GNU_ARM-Linux/fnirsi_1013d.bin -i dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin -l 0x9800" takes the data from fnirsi_1013d_scope.bin and copies it to fnirsi_1013d.bin starting from location 0x9800.
There should already be a fnirsi_1013d.bin file in the directory with the boot loader and splash screen code in it, and then it adds the scope program to it. If there is no existing fnirsi_1013d.bin file it will create it and put zeros in the space before 0x9800.
When there is one with the scope program already in there it will be overwritten with the new data, so it can be reused over and over. No need to rebuild the boot loader and splash screen code as long as there is a valid fnirsi_1013d.bin file with these two in it.
Offline Atlan
  • Country: sk
« Reply #2039 on: February 26, 2024, 05:24:32 pm »
Look again at the last picture I put here, you must not have any other files there.  And no more files with a similar name to txt
I said TP4. No tp1 no tp2
« Last Edit: February 26, 2024, 05:26:44 pm by Atlan »
Offline dfw_ee
« Reply #2040 on: February 27, 2024, 01:54:23 am »
This was very helpful to understand the process of how the sdcard binary is built. The problem was the fnirsi_1013d.bin had all zeros at the top instead of the bootloader and splash screen. I grabbed one that had it and did a build and everything now works.
Thanks!
BTW, I saw your youtube video about the touch screen issue you originally had with it not responding in certain locations. I think I read that is what sent you down this whole reverse engineering path. This work that you did on the reverse engineering is very impressive! Did you get that particular unit to ever work?
Offline dfw_ee
« Reply #2041 on: February 27, 2024, 02:00:39 am »
Thanks, got it working. Many thanks for putting together the TPx programs!!
The following users thanked this post: Atlan
Offline Atlan
  • Country: sk
« Reply #2042 on: February 27, 2024, 04:50:06 am »
Does TP work properly?
« Last Edit: February 27, 2024, 07:30:14 am by Atlan »
« Reply #2043 on: February 27, 2024, 07:16:40 am »
Yes that is what started it all. I did get the unit working again, but with an acrylic screen so it looks a bit shitty.
It was a fun project and I learned a lot from it.
Offline Atlan
  • Country: sk
« Reply #2044 on: February 27, 2024, 07:35:01 am »
PC:
In what range can the numbers be for setting the DC offset
#define HIGH_DC_OFFSET   500
#define LOW_DC_OFFSET   1200
Zero calibration is around 860 - 870
So what are the limits if I want to use it to shift the signal.  Thx
« Last Edit: February 27, 2024, 07:36:57 am by Atlan »
« Reply #2045 on: February 27, 2024, 08:08:41 am »
PC:
The FPGA counts from 0 to 1999 clocked on 50MHz to make the carrier frequency for the offset. So 25KHz at the output. The setting for the pulse width is a 16 bit value but in this case the useful range is 0 to 1999 for 0% to 100%.
As it is running of 3.3V IO this would mean 0 to 3.3V. The used ADC input range is smaller than that due to the input opamps running on 2.5V.
The given high and low values probably come from the original code.
Offline Atlan
  • Country: sk
« Reply #2046 on: February 27, 2024, 09:00:13 am »
According to me, there is a mistake in the scheme, at least my glass versions of the oscilloscope have 3.3V on the operands.
« Last Edit: February 27, 2024, 09:35:05 am by Atlan »
Offline tokar
  • Country: ru
« Reply #2047 on: February 27, 2024, 10:04:25 am »
DC measurements for v0024b CH 1.
For v0024c the table is similar.
« Reply #2048 on: February 27, 2024, 11:46:02 am »
It might well be that they have changed things. The version I used to draw up the schematics definitely has 2.5V on the opamps. Have measured it with a DMM.
Offline Atlan
  • Country: sk
« Reply #2049 on: February 27, 2024, 01:01:13 pm »
Tokar: does that mean it's good?
PC:The reference is 1.25v, so it doesn't matter if the device has 2.5 or 3.3V, because the downward shift from the reference is always the same.
Does anyone have firmware 0.0.  24c on a device that does not have embedded connectors.  That is, the first version of the oscilloscope.  Could you post a screenshot of the diagnostic screen?  (ideally calibrated) but it must be firmware 0.024c and must be after activation of the autorange without a connected signal on both channels.
« Last Edit: February 27, 2024, 01:09:47 pm by Atlan »
