Last uploaded TPczip. In it, all versions of bin, run alternative firmware
Do not change the names of the files in the working folder!!!
mksunxi and flashfilepacker and fnirsi_1013d_scope.elf They must be set in properties as executable.
(Attachment Link)
If the names are correct, the program that is there will combine all 3 bins from the projects into one. fnirsi_1013d.bin
I have used the latest TPczip. I extracted the files and made no changes whatsoever. I did a make in the TP1 directory and it built a .bin file that replaced the .bin file that was already in your directory. It did not replace the combined .txt file. It is the .txt files that actually work. Here is the last part of the build process which seems to match the picture you sent the other day:
arm-none-eabi-objcopy -O binary dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.elf dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin
./mksunxi dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin
bootloader size= 3f000
The bootloader head has been fixed
./flashfilepacker -o dist/Debug/GNU_ARM-Linux/fnirsi_1013d.bin -i dist/Debug/GNU_ARM-Linux/fnirsi_1013d_scope.bin -l 0x9800
From above it looks like only the .bin file is the output and this file does not load on the sdcard. The .txt file that pre-existed in your directory does load. The pre-existing .bin file does not. It behaves the same as the new bin files that I build. No names have been changed nor anything else after the unzipping. How did the .txt files come about? It isn't a simple renaming of the .bin file.
