Thanks for the info. Isn't it possible to use your bit banged I2C code on github to reprogam the touch panel configuration instead of connecting other hardware? It seems that is what happened in the first place. Once again thanks for the help!
Sure it is, but you have to write it yourself. The code can be small enough to do it in the bootloader. Just take that project and remove the loading of the next code and stick in the I2C bit with the needed touch panel configuration. All the needed bits and pieces can be found in what I wrote. It might even still be in the new firmware disabled with a define.
#ifndef USE_TP_CONFIG
#ifdef SAVE_TP_CONFIG
void save_tp_config(void)
//Create a file for the touch panel configuration. Fails if it already exists
if(f_open(&viewfp, "FNIRSI_1013D_tp_config.bin", FA_CREATE_NEW | FA_WRITE | FA_READ) == FR_OK)
//Write the touch panel configuration to the sd card
f_write(&viewfp, tp_config_data, sizeof(tp_config_data), 0);
//Close the file to finish the write
f_close(&viewfp);
#endif
#endif
//Touch panel configuration for the GT9157 set to 800x480 resolution
#ifdef USE_TP_CONFIG
#define USE_LR_CONFIG
#ifdef USE_LR_CONFIG
uint8 tp_config_data[] =
0xFF, 0x20, 0x03, 0xE0, 0x01, 0x0A, 0xFD, 0x00, 0x01, 0x08, 0x28, 0x08, 0x5A, 0x3C, 0x03, 0x05,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x1A, 0x1E, 0x14, 0x87, 0x29, 0x0A, 0x75, 0x77,
0xB2, 0x04, 0x00, 0x00, 0x00, 0x9A, 0x01, 0x11, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x50, 0xA0, 0x94, 0xD5, 0x02, 0x08, 0x00, 0x00, 0x04, 0xA1, 0x55, 0x00, 0x8F,
0x62, 0x00, 0x7F, 0x71, 0x00, 0x73, 0x82, 0x00, 0x69, 0x95, 0x00, 0x69, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x02, 0x04, 0x06, 0x08, 0x0A, 0x0C, 0x0E, 0x10, 0x12, 0x14, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
0x04, 0x06, 0x08, 0x0A, 0x0C, 0x1D, 0x1E, 0x1F, 0x20, 0x21, 0x22, 0x24, 0x26, 0x28, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x01
#else
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18, 0x1A, 0x1E, 0x14, 0x8B, 0x2A, 0x0C, 0x75, 0x77,
0x18, 0x16, 0x14, 0x12, 0x10, 0x0E, 0x0C, 0x0A, 0x08, 0x06, 0x04, 0x02, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x24, 0x22,
0x21, 0x20, 0x1F, 0x1E, 0x1D, 0x1C, 0x18, 0x16, 0x13, 0x12, 0x10, 0x0F, 0x0C, 0x0A, 0x08, 0x06,
0x04, 0x02, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x01,
#endif
#endif
//Clear the checksum before calculating it
checksum = 0;
//Calculate checksum over the configuration data (first 184 bytes)
for(i=0;i<184;i++)
checksum += tp_config_data
//Do the last action to make it the correct checksum
checksum = ~checksum + 1;
//Put the checksum in the buffer
tp_config_data[184] = checksum;
//Send the configuration data
tp_i2c_send_data(TP_DEVICE_ADDR, TP_CFG_VERSION_REG, tp_config_data, sizeof(tp_config_data));
#else
