It looks like that what the special chip does for id 0x11 is not that complex.
If I'm correct it just shifts the data 4 bits to the right and adds two.
The scope code takes the two bytes from the FPGA and does the following:
uint FUN_8001bec4(void)
byte bVar1;
byte bVar2;
uint uVar3;
fpga_write_cmd('\x14');
bVar1 = fpga_read_data();
bVar2 = fpga_read_data();
uVar3 = get_setting(0x11, bVar1 & 0xf | (bVar1 & 0xf) << 0xc | (uint)bVar2 << 4);
return uVar3;
I processed the capture e_Johny made to undo the action done to the FPGA data and show only the parameter 0x11 lines.
The last two bytes of the data in between the second set of brackets show what is received by the chip. (0x7D, 0x97 ==> 0x7D97 ==> 0x07D9)
{ 0x00, 0x51, 0x35, 0x79, 0x19, 0xE6, 0x0D, 0xE7 },{ 0x00, 0x21, 0x45, 0x09, 0x69, 0x96, 0x7D, 0x97 }, //Checksum ok Data: 0x000007D9 Id: 0x11 Len: 1
{ 0x01, 0xCE, 0x6B, 0x5D, 0x58, 0xA7, 0x36, 0xEA },{ 0x01, 0x31, 0x5A, 0x6C, 0x69, 0x96, 0x07, 0xDB }, //Checksum ok Data: 0x000007DB
{ 0x00, 0xAD, 0xE2, 0xED, 0xCE, 0x31, 0x02, 0x5D },{ 0x00, 0x0A, 0x45, 0x4A, 0x69, 0x96, 0xA5, 0xFA }, //Checksum ok Data: 0x00000A5F Id: 0x11 Len: 1
{ 0x01, 0x58, 0xFD, 0xCC, 0xCE, 0x31, 0xAD, 0xC6 },{ 0x01, 0xA7, 0x5A, 0x6B, 0x69, 0x96, 0x0A, 0x61 }, //Checksum ok Data: 0x00000A61
{ 0x00, 0x66, 0xDC, 0xA0, 0xF0, 0x0F, 0x3C, 0x23 },{ 0x00, 0xFF, 0x45, 0x39, 0x69, 0x96, 0xA5, 0xBA }, //Checksum ok Data: 0x00000A5B Id: 0x11 Len: 1
{ 0x01, 0xA4, 0x01, 0x40, 0x32, 0xCD, 0x51, 0x06 },{ 0x01, 0x5B, 0x5A, 0x1B, 0x69, 0x96, 0x0A, 0x5D }, //Checksum ok Data: 0x00000A5D
{ 0x00, 0x62, 0x5C, 0x1C, 0x70, 0x8F, 0xBC, 0xA3 },{ 0x00, 0x7B, 0x45, 0x05, 0x69, 0x96, 0xA5, 0xBA }, //Checksum ok Data: 0x00000A5B Id: 0x11 Len: 1
{ 0x01, 0xFA, 0x5F, 0xC0, 0x6C, 0x93, 0x0F, 0x58 },{ 0x01, 0x05, 0x5A, 0xC5, 0x69, 0x96, 0x0A, 0x5D }, //Checksum ok Data: 0x00000A5D
{ 0x00, 0x60, 0x54, 0x42, 0x78, 0x87, 0xB4, 0xDB },{ 0x00, 0x71, 0x45, 0x53, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x01, 0x1E, 0xBB, 0x43, 0x88, 0x77, 0xEB, 0xBF },{ 0x01, 0xE1, 0x5A, 0xA2, 0x69, 0x96, 0x0A, 0x5E }, //Checksum ok Data: 0x00000A5E
{ 0x00, 0x68, 0x56, 0x3C, 0x7A, 0x85, 0xB6, 0xC9 },{ 0x00, 0x7B, 0x45, 0x2F, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x55, 0xF0, 0xC6, 0xC3, 0x3C, 0xA0, 0xF5 },{ 0x01, 0xAA, 0x5A, 0x6C, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0x63, 0x7C, 0x1D, 0x50, 0xAF, 0x9C, 0xA3 },{ 0x00, 0x5A, 0x45, 0x24, 0x69, 0x96, 0xA5, 0x9A }, //Checksum ok Data: 0x00000A59 Id: 0x11 Len: 1
{ 0x01, 0x60, 0xC5, 0xC2, 0xF6, 0x09, 0x95, 0xC4 },{ 0x01, 0x9F, 0x5A, 0x5D, 0x69, 0x96, 0x0A, 0x5B }, //Checksum ok Data: 0x00000A5B
{ 0x00, 0x9A, 0x0B, 0x13, 0x27, 0xD8, 0xEB, 0x84 },{ 0x00, 0xD4, 0x45, 0x5D, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x01, 0xD7, 0x72, 0xC1, 0x41, 0xBE, 0x22, 0x76 },{ 0x01, 0x28, 0x5A, 0xE9, 0x69, 0x96, 0x0A, 0x5E }, //Checksum ok Data: 0x00000A5E
{ 0x00, 0x30, 0x04, 0xA2, 0x28, 0xD7, 0xE4, 0x8B },{ 0x00, 0x71, 0x45, 0xE3, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x01, 0x38, 0x9D, 0x4F, 0xAE, 0x51, 0xCD, 0x99 },{ 0x01, 0xC7, 0x5A, 0x88, 0x69, 0x96, 0x0A, 0x5E }, //Checksum ok Data: 0x00000A5E
{ 0x00, 0xA2, 0x48, 0x58, 0x64, 0x9B, 0xA8, 0xC7 },{ 0x00, 0xAF, 0x45, 0x55, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x00, 0x91, 0x21, 0x20, 0x0D, 0xF2, 0xC1, 0xAE },{ 0x00, 0xF5, 0x45, 0x44, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x01, 0x9A, 0x3F, 0x43, 0x0C, 0xF3, 0x6F, 0x3B },{ 0x01, 0x65, 0x5A, 0x26, 0x69, 0x96, 0x0A, 0x5E }, //Checksum ok Data: 0x00000A5E
{ 0x00, 0xB6, 0x88, 0x5E, 0xA4, 0x5B, 0x00, 0x21 },{ 0x00, 0x7B, 0x45, 0x93, 0x69, 0x96, 0xCD, 0xEC }, //Checksum ok Data: 0x00000CDE Id: 0x11 Len: 1
{ 0x01, 0xC9, 0x6C, 0x4D, 0x5F, 0xA0, 0x3A, 0xD6 },{ 0x01, 0x36, 0x5A, 0x7B, 0x69, 0x96, 0x0C, 0xE0 }, //Checksum ok Data: 0x00000CE0
{ 0x00, 0xB5, 0xA0, 0xD3, 0x8C, 0x73, 0x40, 0x3F },{ 0x00, 0x50, 0x45, 0x36, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x7C, 0xD9, 0xC6, 0xEA, 0x15, 0x89, 0xDC },{ 0x01, 0x83, 0x5A, 0x45, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0x91, 0x21, 0x30, 0x0D, 0xF2, 0xC1, 0xBE },{ 0x00, 0xF5, 0x45, 0x54, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x53, 0xF6, 0xC2, 0xC5, 0x3A, 0xA6, 0xF3 },{ 0x01, 0xAC, 0x5A, 0x6E, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0x51, 0x35, 0x54, 0x19, 0xE6, 0xD5, 0xFA },{ 0x00, 0x21, 0x45, 0x24, 0x69, 0x96, 0xA5, 0x8A }, //Checksum ok Data: 0x00000A58 Id: 0x11 Len: 1
{ 0x01, 0x7E, 0xDB, 0xBF, 0xE8, 0x17, 0x8B, 0xDB },{ 0x01, 0x81, 0x5A, 0x3E, 0x69, 0x96, 0x0A, 0x5A }, //Checksum ok Data: 0x00000A5A
{ 0x00, 0x25, 0xE4, 0x47, 0xC8, 0x37, 0x04, 0x3B },{ 0x00, 0x84, 0x45, 0xE6, 0x69, 0x96, 0xA5, 0x9A }, //Checksum ok Data: 0x00000A59 Id: 0x11 Len: 1
{ 0x01, 0x28, 0x8D, 0x42, 0xBE, 0x41, 0xDD, 0x8C },{ 0x01, 0xD7, 0x5A, 0x95, 0x69, 0x96, 0x0A, 0x5B }, //Checksum ok Data: 0x00000A5B
{ 0x00, 0xBF, 0xAA, 0xD7, 0x86, 0x79, 0x4A, 0x25 },{ 0x00, 0x50, 0x45, 0x38, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x00, 0x5A, 0x1F, 0x37, 0x33, 0xCC, 0xFF, 0xC0 },{ 0x00, 0x00, 0x45, 0x6D, 0x69, 0x96, 0xA5, 0x9A }, //Checksum ok Data: 0x00000A59 Id: 0x11 Len: 1
{ 0x01, 0xA1, 0x04, 0x42, 0x37, 0xC8, 0x54, 0x05 },{ 0x01, 0x5E, 0x5A, 0x1C, 0x69, 0x96, 0x0A, 0x5B }, //Checksum ok Data: 0x00000A5B
{ 0x00, 0x61, 0x74, 0x53, 0x58, 0xA7, 0x94, 0xEB },{ 0x00, 0x50, 0x45, 0x62, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0xDB, 0x7E, 0xC2, 0x4D, 0xB2, 0x2E, 0x7B },{ 0x01, 0x24, 0x5A, 0xE6, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0x5A, 0x1F, 0x07, 0x33, 0xCC, 0xFF, 0x90 },{ 0x00, 0x00, 0x45, 0x5D, 0x69, 0x96, 0xA5, 0xCA }, //Checksum ok Data: 0x00000A5C Id: 0x11 Len: 1
{ 0x01, 0x12, 0xB7, 0x43, 0x84, 0x7B, 0xE7, 0xB3 },{ 0x01, 0xED, 0x5A, 0xAE, 0x69, 0x96, 0x0A, 0x5E }, //Checksum ok Data: 0x00000A5E
{ 0x00, 0x49, 0x77, 0x2E, 0x5B, 0xA4, 0x97, 0xD8 },{ 0x00, 0x7B, 0x45, 0x1C, 0x69, 0x96, 0xA5, 0xEA }, //Checksum ok Data: 0x00000A5E Id: 0x11 Len: 1
{ 0x01, 0x7A, 0xDF, 0xCD, 0xEC, 0x13, 0x8F, 0xE5 },{ 0x01, 0x85, 0x5A, 0x48, 0x69, 0x96, 0x0A, 0x60 }, //Checksum ok Data: 0x00000A60
{ 0x00, 0xE6, 0xD8, 0xFC, 0xF4, 0x0B, 0x38, 0x07 },{ 0x00, 0x7B, 0x45, 0x61, 0x69, 0x96, 0xA5, 0x9A }, //Checksum ok Data: 0x00000A59 Id: 0x11 Len: 1
{ 0x01, 0xB7, 0x12, 0x4E, 0x21, 0xDE, 0x42, 0x13 },{ 0x01, 0x48, 0x5A, 0x06, 0x69, 0x96, 0x0A, 0x5B }, //Checksum ok Data: 0x00000A5B
{ 0x00, 0x25, 0xE4, 0x87, 0xC8, 0x37, 0x04, 0x7B },{ 0x00, 0x84, 0x45, 0x26, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x3D, 0x98, 0x46, 0xAB, 0x54, 0xC8, 0x9D },{ 0x01, 0xC2, 0x5A, 0x84, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0xBE, 0x8A, 0xC6, 0xA6, 0x59, 0x6A, 0x15 },{ 0x00, 0x71, 0x45, 0x09, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x8E, 0x2B, 0x42, 0x18, 0xE7, 0x7B, 0x2E },{ 0x01, 0x71, 0x5A, 0x33, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0xF5, 0xB0, 0x23, 0x9C, 0x63, 0x50, 0x2F },{ 0x00, 0x00, 0x45, 0xD6, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0x79, 0xDC, 0xCE, 0xEF, 0x10, 0x8C, 0xD9 },{ 0x01, 0x86, 0x5A, 0x48, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
{ 0x00, 0xBB, 0x2A, 0xA3, 0x06, 0xF9, 0xCA, 0xF5 },{ 0x00, 0xD4, 0x45, 0xCC, 0x69, 0x96, 0xA5, 0x9A }, //Checksum ok Data: 0x00000A59 Id: 0x11 Len: 1
{ 0x01, 0xE9, 0x4C, 0xC2, 0x7F, 0x80, 0x1C, 0x4D },{ 0x01, 0x16, 0x5A, 0xD4, 0x69, 0x96, 0x0A, 0x5B }, //Checksum ok Data: 0x00000A5B
{ 0x00, 0x3A, 0x0E, 0xC6, 0x22, 0xDD, 0xEE, 0x91 },{ 0x00, 0x71, 0x45, 0x8D, 0x69, 0x96, 0xA5, 0xDA }, //Checksum ok Data: 0x00000A5D Id: 0x11 Len: 1
{ 0x01, 0xD2, 0x77, 0xC2, 0x44, 0xBB, 0x27, 0x72 },{ 0x01, 0x2D, 0x5A, 0xEF, 0x69, 0x96, 0x0A, 0x5F }, //Checksum ok Data: 0x00000A5F
The question now is what is going on in the FPGA that makes it return these different values when command 0x14 is read.
