I made a new version. I was right about that the slave address initialization was also removed. Nopped the call to the send the configuration function to stop only that part. Uploaded it to the hacked files section of the repository. Tested it with my I2C monitor connected and some of the other calls to the touch panel that where removed are now back in.
So the new patched file should work on every power up. Tested it a couple of times. The touch panel needs to have the right configuration of coarse.
Here is the startup communication with the touch panel
S
0x28 A 0x80 A 0x40 A 0x02 A P
//Config used to be send here
S
0x28 A 0x80 A 0x40 A 0x00 A P
S
0x28 A 0x81 A 0x4E A S
0x29 A 0x80 N P
S
0x28 A 0x81 A 0x4E A 0x00 A P
S
0x29 A 0x00 N P
S
0x29 A 0x00 N P
S
0x29 A 0x00 N P
Analyzed the function to what it is doing and added comments
undefined4 FUN_8001794c(void) //This is the function that sets up the configuration for the touch panel
char *pcVar1;
undefined4 uVar2;
byte bVar3;
uint uVar4;
undefined4 in_r3;
int iVar5;
undefined4 local_10;
uVar2 = DAT_80017ab4; //0x01C20800. Base register address for Port A
local_10 = in_r3;
FUN_8001764c(DAT_80017ab4,3,1,0); //Setup SCL (PA3) as output
FUN_8001764c(uVar2,2,1,0); //Setup SDA (PA2) as output
FUN_8001774c(uVar2,3); //Set SCL high
FUN_8001774c(uVar2,2); //Set SDA high
FUN_8001764c(uVar2,0,1); //Setup RESET (PA0) as output. Start of slave address init of touch panel
FUN_8001764c(uVar2,1,1,0); //Setup INT (PA1) as output
FUN_80017738(uVar2,0); //Set RESET low
FUN_80017738(uVar2,1); //Set INT low
FUN_8000bc34(100); //Delay function. 100
FUN_8001774c(uVar2,1); //Set INT high. Sequence for selecting 0x14 as slave address (0x28/0x29, write/read bytes)
FUN_8000bc34(DAT_80017ab8); //Delay again. 20000 (Should be 100uS)
FUN_8001774c(uVar2,0); //Set RESET high
FUN_8000bc34(DAT_80017abc); //Delay again. 10000
FUN_8001764c(uVar2,1,0); //Set INT as input
FUN_8000bc34(DAT_80017ac0); //Wait again. 100000
uVar2 = DAT_80017ac4; //0x00008040
local_10._0_1_ = 2;
FUN_80017d2c(DAT_80017ac4,&local_10,1); //Write 0x02 to register address 0x8040. Touch Panel command (read diff data or raw data)
bVar3 = 0;
uVar4 = 0;
do
pcVar1 = (char *)(DAT_80017ac8 + uVar4); //There is a buffer at 0x8019CF82 in RAM where it calculates the checksum for the config of the touch panel
iVar5 = DAT_80017ac8 + uVar4;
uVar4 = uVar4 + 2 & 0xfffeffff;
bVar3 = *(char *)(iVar5 + 1) + bVar3 + *pcVar1;
} while (uVar4 < 0xb8);
*(byte *)(DAT_80017ac8 + 0xb8) = ~bVar3 + 1;
//This is the function I nopped out with mov r0,r0
FUN_80017d2c(DAT_80017acc,DAT_80017ac8,0xba); //Write the configuration data the the touch panel starting from register address 0x8047
FUN_8000bc34(DAT_80017ad0); //Wait again. 200000
local_10 = (uint)local_10._1_3_ << 8;
FUN_80017d2c(uVar2,&local_10,1); //Write 0x00 to register address 0x8040. Touch Panel command (read coordinate status)
return 0;
