Author Topic: Siglent SDS3000X HD and upgraded SDS1000X HD  (Read 429772 times)
temperance, Antonio90, hansibull and 6 Guests are viewing this topic.
Offline Performa01
  • Country: at
Re: Siglent SDS3000X HD and upgraded SDS1000X HD
« Reply #950 on: August 02, 2024, 01:31:25 pm »
I use only the web interface. I have never used flash with SDS3000X HD.
Yes, older FW always used the same simple filename. But current FW makes that distinction and you can easily try this by repeating my experiment, i.e. saving a screenshot to a flash drive.
The Filename used for saving to flash is configurable by the way...
Online egonotto
« Reply #951 on: August 02, 2024, 01:57:36 pm »
Hello,
the behavior when generating the file names in the web interface has changed without me having made a firmware change. I suspect that a function in the browser has been changed. I will check this by using a different browser.
My suspicion was correct. Firefox still generates names like ScreenImg(2).png.
So it was the Edge browser.
Best regards
egonotto
The following users thanked this post: Performa01
Online 2N3055
  • Country: hr
« Reply #952 on: August 02, 2024, 02:14:37 pm »
Let me remind everybody that if you create a map to a folder on your PC (using SMB Client), then you can directly save to PC.
Also, since scope remembers last filesystem used, once you save to PC firstly, from that point on it will keep saving there.
So you press [Save]button on scope, and screenshot ends up on a PC. Or data, whatever is set.
Pay attention that 3000xHD saves data to PC at almost 100MBytes/sec... It is very fast.
The following users thanked this post: Performa01, egonotto
Online Bad_Driver
« Reply #953 on: August 04, 2024, 06:16:50 pm »
My workflow is easy. Making a screenshot in the web interface, open it in the download folder with Irfanview (my standard image viewer), invert it for printing or combine it with other snapshots and store it in a dedicated folder with an dedicated name for later use as JPG.
The following users thanked this post: Performa01, egonotto, 2N3055
Online 2N3055
  • Country: hr
« Reply #954 on: August 04, 2024, 09:21:24 pm »
And that is what I also do..
But sometimes, as you work on something, you can simply document things as you go, directly from the scope. Or when testing a small batch or repeating measurement while making changes on circuit. There are many scenarios where it is simply more ergonomic not to jump between PC and what you work on.
We are fortunate that we can choose way that suits us best.
The following users thanked this post: Performa01, egonotto, Bad_Driver
Offline nimish
« Reply #955 on: August 05, 2024, 07:44:24 pm »
GbE being considered "fast" on a $3000 device is so disappointing. The FPGAs can support 10g+ if only the manufacturers exposed a sfp+ cage
Online 2N3055
  • Country: hr
« Reply #956 on: August 05, 2024, 07:53:10 pm »
And it can support anti aircraft gun too if you add that too...
Better check what kind of speed you get from competition...
Online Martin72
  • Testfield Technician
« Reply #957 on: August 05, 2024, 08:05:32 pm »
In practice, there is a difference between possible and sensible.
(Kierkegaard)
Online egonotto
« Reply #958 on: August 06, 2024, 02:02:34 am »
Hello,
I would like it, if there was a USB3 streaming mode.
Best regards
egonotto
Online egonotto
« Reply #959 on: August 18, 2024, 07:17:43 am »
Hello,
I had a look at what you can achieve with average.
Best regards
egonotto
PS: With the MHO3 you can only set 256 averages and only get 1.7 uV (AC RMS) and 15 uV (pp) with comparable settings.
« Last Edit: August 18, 2024, 07:22:08 am by egonotto »
Online Bad_Driver
« Reply #960 on: Yesterday at 06:43:25 pm »
I did the same with my SDS2000X HD fyi, see attached. Seems to be a little bit noisier.
Egonotto, why have you limited the sample rate to 100 MSa/s?
« Last Edit: Yesterday at 06:46:00 pm by Bad_Driver »
Online egonotto
« Reply #961 on: Today at 09:49:25 am »
Hello,
there are a few threads here that deal with accurate and extreme LCR measurements. This has inspired me to see what is possible with an Analog Discovery. It's quite good, if you disregard the accuracy. However, the Analog Discovery only has 500 mV/div, so I wanted to know what could be achieved with an SDS3000X HD. The selected settings seemed to me to be a good fit.
Best regards
egootto
Online Martin72
« Reply #962 on: Today at 06:51:16 pm »
Sounds interesting.
Which software can be seen in the picture?
And the data for this came from the 3000X HD?
(Kierkegaard)
Online 2N3055
  • Country: hr
« Reply #963 on: Today at 07:09:54 pm »
Sounds interesting.
That is Waveforms software for Analog Discovery.
You can try it, it is interesting. Works with a sound card for basic testing..
The following users thanked this post: egonotto, Martin72
Online egonotto
« Reply #964 on: Today at 07:28:31 pm »
Sounds interesting.
Hello,
no, the picture is from the Analog Discovery 3. but if you consider how much more sensitive the SDS3000X HD is, for example, you can imagine what good results you could achieve with it and a function generator. Not only is it more sensitive, but you can also adjust the V/div in the program (that still needs to be written).
If you consider that a coil of 1 uH at 100 Hz has about 0.628 mOhm, but at 10 MHz it already has 62.8 kOhm.
The Analog Discovery could no longer measure anything at 100 Hz, but the SDS3000X HD could still measure the 12.6 uV at 20 mA.
Best regards
egonotto
The following users thanked this post: mathstudi
Online Martin72
« Reply #965 on: Today at 07:46:35 pm »
OK, I figured since it was posted here in this thread, there must be some reference to it.
The user mawyatt had already done something similar, albeit not with an HD scope.
https://www.eevblog.com/forum/testgear/capacitive-impedance-plots-with-sds2104x-plus-bode-function/msg4335745/#msg4335745
I still think the request to Siglent contained therein is worth supporting... ;)
(Kierkegaard)
The following users thanked this post: egonotto, temperance, KungFuJosh, Antonio90, mathstudi
