Hi, I received the touch screen yesterday. First I've veryfied 6pin tape connection. 1. RST, 2. Vcc, 3. GND, 4. INT, 5. SDA, 6. SCL. It was the same that the original. I,ve found that the screen has its own pull up resistors (SDA, SCL). On the main board there are already pull up resisors. So one of them should be removed. I decided to remove them from the touch screen.
Time to connect everyting together. The scope starts to work. Touch screen works properly !!!
I've noticed that because of the touch screen is a little bit biger than the original it seems the picture fits the whole LCD. It is a little biger so the front glass frame could be now smaler (2..3 mm?). I'm not sure of this efect because I cant compare it to the original.
The touch screen has its own adhensive tape so I've glued it to LCD. Next I've put double sided adhensive tape on the front glass (enough wide to be possible to glue plastic housing and then screen). I put the glass into plastic housing and then put LCD screen).
