Author Topic: FNIRSI-1013D "100MHz" tablet oscilloscope  (Read 799950 times)
engineer.r152 and 8 Guests are viewing this topic.
Offline Magua
  • Country: ru
Re: FNIRSI-1013D "100MHz" tablet oscilloscope
« Reply #2175 on: April 01, 2024, 06:12:26 pm »
« Last Edit: April 02, 2024, 08:12:33 am by Magua »
The following users thanked this post: facekim
Online engineer.r152
  • Country: ru
« Reply #2176 on: April 02, 2024, 05:34:50 am »
Good afternoon! The firmware is fnirsi_1013d_v0.024t. There are problems with saving waveforms in ACQ Long mode. I save the waveform on the video and false steps and a further continuation of the signal appear in the save done.
https://youtu.be/vl45CdwSL7U?feature=shared
« Last Edit: April 02, 2024, 05:39:26 am by engineer.r152 »
Offline gadak
  • Country: al
« Reply #2177 on: April 02, 2024, 10:31:22 am »
In firmware 0.024t after pressing autoset the actual value is still different from the measured oscilloscope, also confirm it is not possible to view the recorded image and video oscillogram.
https://youtu.be/2Tv0On6prPk
Offline stedivid
  • Country: ru
« Reply #2178 on: April 02, 2024, 02:27:17 pm »
Good afternoon, everyone. Please share the factory firmware of the oscilloscope. accidentally deleted the firmware.
Online pcprogrammer
« Reply #2179 on: April 02, 2024, 02:39:30 pm »
You can find a couple versions here.
Offline Atlan
  • Country: sk
« Reply #2180 on: April 02, 2024, 04:05:51 pm »
set 7.5V, connect DC voltage, press autoset. Check the AVG value and write it here. Open the channel menu, highlight AC and then back to DC (don't leave the channel menu). Exit the channel menu, and check the AVG value again and write it here. or video.
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
The following users thanked this post: stedivid
Offline Atlan
  • Country: sk
« Reply #2181 on: April 02, 2024, 04:07:03 pm »
Did you make a flash backup? then you have a problem. You will not have a calibrated oscilloscope.
Offline Atlan
  • Country: sk
« Reply #2182 on: April 02, 2024, 04:10:09 pm »
The following users thanked this post: tokar, facekim, stedivid
Offline Magua
  • Country: ru
« Reply #2183 on: April 02, 2024, 05:25:28 pm »
fnirsi_1013d.bin v0.024u
The problem is probably something else
https://youtu.be/-bo5IEjTrlA
Offline tokar
  • Country: ru
« Reply #2184 on: April 02, 2024, 05:56:37 pm »
  • Country: ru
« Reply #2185 on: April 03, 2024, 05:21:23 am »
There is a departure of the zero position of the beam after pressing the autoset button.
https://youtu.be/RiFy97TEnFI?feature=shared
Offline tokar
  • Country: ru
« Reply #2186 on: April 03, 2024, 07:32:44 am »
On the original firmware in DC mode it works exactly like this: shifting the marker “0” to make maximum use of the screen size along the Y axis. When you press the Autoset button, it makes it possible to observe the DC+AC signal, with maximum amplitude, without additional settings.
https://youtu.be/PvyyLhLGvew
Offline Magua
  • Country: ru
  • Country: ru
« Reply #2188 on: April 03, 2024, 10:41:07 am »
A proposal to modernize the program. You can add a button that will return the beam to the zero position. On other oscilloscopes, this happens by pressing the beam displacement encoder. For example, you could click on the zone between V+ and V-
The following users thanked this post: bffargo
Offline madori
  • Country: hr
« Reply #2189 on: April 03, 2024, 06:20:25 pm »
-Way lose Measure on long mode.
-have calibrated with good source and good multimeter, still have doubt,
-rpm calculation, during relative compresion start  (1000 / T) x 60= rpm/min   (have used hantek c650)
Is it there some shorted how and what, just get through all this forum pages. but..
-original firmware backup
-Improving hardware advice if needed
Using tricks
Offline gadak
  • Country: al
« Reply #2190 on: April 03, 2024, 06:43:25 pm »
"set 7.5V, connect DC voltage, press autoset. Check the AVG value and write it here. Open the channel menu, highlight AC and then back to DC (don't leave the channel menu). Exit the channel menu, and check the AVG value again and write it here. or video."
I did as you wrote. I also noticed that the voltage drops by 0.3 volts when I connect the dipstick.
https://youtu.be/Hx_uuO6MV24
Offline madori
  • Country: hr
Offline Atlan
  • Country: sk
« Reply #2192 on: April 11, 2024, 06:42:29 am »
What should we learn from the video?
Otherwise, I thought about whether the problem with the DC shift is also caused by the discharge of the battery.  Because pwm is fixed, but when the battery voltage is low, a different shift is made that does not match the calculation.  How many DC to 5V converter do you have?
Offline Ruskie
« Reply #2193 on: April 13, 2024, 03:39:57 pm »
Hello everyone. Apologies if this question has been asked, but for the nature of it I find it difficult to search.
I have received my 1013D brand new, and immediately patched successfully with the latest alternative fw I found on github. If that matters, I only "prepared" everything and applied the fw "main" .bin file.
Now, I am not an expert but when turning on the original fw I had this screen as in OriginalFW.jpg.
After installing the new fw I had this screen as in CustomFW.jpg.
Is it normal?
I figured out that the Trigger symbol is placed higher, with the new fw there is new option set by default to have Trigger auto-placed at 50%.
But what about the offset between the 1> / 2> channel symbols and their respective "empty" signals?
Is it correct that they are not aligned anymore?
EDIT: I found that performing calibration (Menu -> System setting -> Baseline calibration) it gets back to 1> and signal level to be on the same page.
Was that "my problem"? That is, after fw changes the oscilloscope need to be recalibrated? Thanks
« Last Edit: April 13, 2024, 03:47:48 pm by Ruskie »
Offline Atlan
  • Country: sk
« Reply #2194 on: April 13, 2024, 04:42:43 pm »
You have the 0.006 version there and it is currently 0.024s, see the back page.  There is a huge difference between them.
0.024t and higer is beta verzia
Manual is on page 82
« Last Edit: April 13, 2024, 04:50:59 pm by Atlan »
The following users thanked this post: Ruskie
Offline Ruskie
« Reply #2195 on: April 14, 2024, 08:17:09 am »
Oh! Wow! It's that I found a "FNIRSI alternative fw repository" on github and linked in a message from somebody here, so I assumed it was the most updated, thank you for the information.
However, I found the latest yesterday evening (if I'm not wrong it's 0.24s) and the manual you linked, and one thing that I can't really understand is this:
In the oscilloscope menu, click on the option Base line calibration.
The required calibration voltages for the ranges are:
   100mV/div 300mV
   200mV/div 600mV
   500mV/div 1.5V
   1V/div  3V
   2.5V/div 7.5V
   5V/div  15V
Use an analog voltage source, or battery voltage that has zero ripple.
Does this mean that the calibration process is no longer "self contained", and I need some "external tool" of some sort? If so, is there any more detailed explanation, in a document or video?
Online csuhi17
  • Country: hu
« Reply #2196 on: April 14, 2024, 08:46:07 am »
This is how you should do it.
Added possibility to reset calibration values. (if a bad calibration occurs) Added notification of a faulty calibration if the offset cannot be set (only if there is some hardware problem, bad ad converter, missing ad converter, problem with the offset voltage setting)
Input divider calibration is enabled when the oscilloscope is turned on for the first time and baseline calibration is used.
Calling up the calibration of the input divider is possible only through the menu by resetting the calibration values. (or by deleting the data on the sd card where the configuration data is located. NEED SDCART READER No It can be done with a card stored in the oscilloscope. )
After successful calibration of the input divider and switching off the oscilloscope, the data is written to the SD card. (Unless you change the burnt components on the input circuits, it will no longer be needed - that is, if you do not erase, do not replace the sd card)
If the calibration is started again, only the base level calibration will be performed. i.e. 0 is found. (What sometimes needs to be done)
By uploading the firmware, the calibration of the input divider DOES NOT CHANGE.
« Last Edit: April 14, 2024, 08:48:44 am by csuhi17 »
Fnirsi oscilloscope = waste&regret
Offline Ruskie
« Reply #2197 on: April 14, 2024, 10:29:06 am »
Apologies, this is for sure entirely my fault but... "how"?
From the video I can understand there is a voltmeter attached, ok... but what is connected to what is not visibile. Plus, the label on the scope says "set to 300mv"... but in the voltmeter you "measure", you don't "set" anything; so, do I need a signal generator as well, or a variable power source that I can set to those values?
Offline Atlan
  • Country: sk
« Reply #2198 on: April 14, 2024, 11:36:10 am »
Yes
Offline Ruskie
« Reply #2199 on: April 14, 2024, 12:09:45 pm »
Yes
Thanks Atlan. This is it then. I am out of luck for now.  |O I have no variable power source.
Does this mean that if I flash the latest version of the fw it would give "wrong" figures unless I perform the calibration as described?
