Since I used bin for backup, after using make, it probably just inserted a new code into the backup BIN. by deleting the scope bin, replacing it with a functional scope bin, it works already after using make. at least I hope so, because I fixed the mistake. so hopefully it will work after all.
DC mode. When measuring a signal with a DC shift. For example, 5V PWM from uP, does not display frequency, duty and time.
Fixed in
firmware 0.024iTokar, can you check if this update also made autoset faster? for signals with a DC shift?
Now I remembered that there are unfinished things in channel switching. That's how it is when it is done on two things at once.
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
