3.Displays real unfiltered waveforms ( the original displays an imaginary waveform )
No bug with switch 100mV
It works from 0V (unlike the original)
It doesn't freeze.
The cursor shows Y1 and Y2 and the difference between Y1 and Y2
Possibility to add time and date ( If the RTC circuit is installed )
Ability to choose sensitivity directly from the channel menu
The measurement menu items are on the right side
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Quick selection of all measurement items, quick cancellation of all measurement items.
Improved appearance
The firmware is constantly improved. ( original firmware never )
disadvantage
no FFT (It's in the plan)
Buffer 3000byte per chanel in FPGA
1 and 2 will be answered by the original programmer.
