Hello,
I tore down the Voltcraft IT-1500 isolation transformer I just received and took some pictures. I figured people here might appreciate them.
https://imgur.com/a/W0isYG9 (Files too large to upload directly to forum)
What I find curious is that they used an unearthed plug for the input to the transformer. Now here in the Netherlands (and I assume Germany) it's not uncommon to find older houses with ungrounded sockets that you can plug earthed schuko connectors into. So perhaps this is up to code. Anyone know if there's a reason they would omit an earth? If not I might add one myself.
The output not having an earth connection seems to be a topic of hot debate when it comes to isolation transformers so at least that makes sense.
edit: It's hard to see in the pics I took and I forgot to explicitly mention. The output does not have earth prongs.
