Author Topic: NI (Ni-9260) alternative for other OS  (Read 711 times)
Offline HenrikWoTopic starter
« on: October 23, 2023, 12:06:16 pm »
I am looking for a voltage output module with which I can stream (close to realtime) a voltage signal from e.g. Matlab or similar.
The output requirements are as follows:
    - Frequency range: DC up to min. 50 kHz (preferably 100 - 200 kHz)
    - Output voltage: anything between +/- 3 V and +/- 10 V
    - DAC resolution: 24 bits
1. for frequencies above 10 Hz I currently use RME sound cards. This is relatively inexpensive but unfortunately DC is not possible with them!
2. for DC I am currently dependent on NI, specifically the Ni-9260 module, but unfortunately the card only manages 51.2 kS/s.
Does anyone know an output module that combines "both worlds" and is open for different operating systems (Windows, Linux, macOS)? I would like to get away from NI hardware for various reasons (which should not be a topic here!). For suggestions and ideas I would be super grateful!
Offline maxwell3e10
Re: NI (Ni-9260) alternative for other OS
« Reply #1 on: October 23, 2023, 08:41:43 pm »
There are many DAC audio devices that have DC-coupled output, Topping or SMSL brands for example. They typically have a small constant DC offset of around 1 mV, but otherwise work well at low frequency. I don't know if there are 24-bit analog output devices that work at frequencies above audio range.
The following users thanked this post: HenrikWo
Offline RiZsho
  • Country: si
« Reply #2 on: October 24, 2023, 08:19:33 am »
Maybe www.dewesoft.com ? They have some ADCs in the 100k-200k (even 1M), but DACs I don't know.
« Reply #3 on: October 24, 2023, 08:53:45 am »
Thanks for the hint with the DC-coupled outputs. I really did not have that on the screen! My "RME ADI-2 Pro FS R" should come back tomorrow from a measurement. I looked more closely into the data sheet and it should also be able to do that... I will extensively test this in the coming days and report here.
« Reply #4 on: October 27, 2023, 12:55:00 pm »
Hi, I found the time to take a closer look at the output of the "RME ADI-2 PRO FS R".
Measuring device: Keysight 34465A
DC: Measurement time 600 s; DC aperture 100 ms; 2000 Samples
< 3 Hz: Measurement time 60 s; DC aperture 50 us; Sample time 1 ms; 50k Samples
> 3 Hz: Measurement time 25 s; AC bandwidth 3 Hz; 100 Samples
The results are attached! Have fun with it if anyone is interested!!!
The following users thanked this post: maxwell3e10
