If I leave my T110 probes hooked together, as in the picture, they are the correct width apart to match the Schuko connector. I actually find that with light pressure and twisting, as though you are tightening and un-tightening a bolt, you can push the tester into the socket without too much issue.
I am curious, if your 4mm adapters on your tester are actually 4mm? Mine are slightly bigger than standard 4mm and do not always go into a 4mm test socket.
Hi 3p,
I noticed that they stick-out a tiny bit (see pictures), and that sharp point is not truly help-full. I also tried unscrewing not fully, but its then to loose IMO.
I also use the probes "interconnected".
My fluke pins are 4.2mm, the normal socket pins are 4.8mm.
I took some pins out of a normal plug, and pushed them on. Now it works
much better. But does not feel safe (and if you push to far they tend to stick in). I assume that the way the vendor made the "child-lock" has something to do with it as-well.
But it would be nice if Fluke would made some other probe versions that you can simply screw on and are good match (4.8mm) for the Schuko socket. I mean thats (among other things) where its for? To me this feels like a fail
I made a video, but not a clue where to upload it (its to big).
Cheers.
BTW, did you manage to disable to beep? I tried the 2 sec light button (in the manual), but nothing happens
