Author Topic: Siglent SDS 1104X-E Sampling issue  (Read 1330 times)
Offline MoriambarTopic starter
« on: October 21, 2018, 08:50:14 am »
Hello, beginner here.
I noticed that with two channels active the 1104x-e halves the sampling rate to 500M (and memory depth), although I thought that this would only happen with three or more active channels. What am I missing?Being a newbie sucks ass sometimes Firmware is updated to latest version.
Cheers.
Re: Siglent SDS 1104X-E Sampling issue
« Reply #1 on: October 21, 2018, 08:58:51 am »
Cheers.
When needing 2 channels at the max sampling rate and memory depth they each need to be used on each of the ADC's.
So any combo of the following:
1+3, 1+4, 2+3, 2+4.
Using any 3rd channel will halve the mem depth and sampling rate.
The following users thanked this post: Moriambar
« Reply #2 on: October 21, 2018, 09:01:24 am »
Cheers.
1+3, 1+4, 2+3, 2+4.
Wow, thanks! I did not thin about this! I am happy I learned something!
Cheers
« Reply #3 on: October 21, 2018, 09:07:03 am »
Cheers.
1+3, 1+4, 2+3, 2+4.
Cheers
This is the standard setup with dual interleaved ADC DSO's. Now you know and aren't likely to forget.  :)
Enjoy.
Oh, and BTW, the memory is configured 14 Mpts times 2, that is, each ADC has 14 Mpts of memory support.
« Last Edit: October 21, 2018, 09:11:27 am by tautech »
« Reply #4 on: October 21, 2018, 09:08:09 am »
Yes indeed!
Offline rf-loop
« Reply #5 on: October 21, 2018, 02:51:43 pm »
Cheers.
1+3, 1+4, 2+3, 2+4.
Cheers
