The placement of conductor in the fork is awfully finicky. When I'm checking for potentially lethal levels of electricity, finicky on my list of desired features.
As for the grounding pad on the back, that just seems like trouble. Is it a high-impedance path under normal conditions? Yes. Now what happens in a gross overload condition when a couple internal components vaporize and the inside of the unit is filled with conductive plasma?
Finicky gimmicks aren't what made Fluke the most trusted name in hand-held meters.
Do you have a way to test how finicky it is? This is what I would have liked to have seen in a review but was unable to find one. Different wire sizes, insulation thicknesses, voltage levels..... Lots of tests could have been run so show it off.
No one measured the current through the meter with it in all of the modes using the meters highest rated voltage. Or at any voltage for that matter.
When you remove the ground lead from the rear, you detach the button. May be ok. When you have the ground lead installed, the human holding it may be enough to prevent the meter from overloading and creating a plasma. If you can get the GDT to break over, say 2KV, you have say a 1.5K resistor now in series with your body.... Hard to say. I assume they certified it for safety.
Then again, I bought a Gossen that can throw up low voltage readings if it gets near a magnetic hanger.
I'm sure it passes the safety standards but it seems IEC never considered a magnetic force like this. Gossen's marketing people may not have listened to the engineers who thought it was a bad idea to put unshielded latching relays in a meter. Maybe there are things with this meter that IEC did not consider, like using a human as a return path.
Too bad the manufacture's and other big players never weigh in here. We could all learn a lot from the experts.
