Author Topic: nk block codes  (Read 3195 times)
Offline tec5cTopic starter
nk block codes
« on: October 29, 2015, 01:50:46 pm »
Sorry for posting in the wrong thread. "Desperate times call for desperate measures..."
I have a question in regards to (n,k) block codes. For a given value of k i.e., (n, 54) which is guaranteed to correct t=10 errors and L is an integer such that L >= n.
What is the numerical value for L?
I don't really understand what L is representing. My assumption is that n is the optimal value for bandwidth efficiency however L is acceptable just with some trade offs.
Is this assumption accurate?
Secondly, I have tried multiple approaches to finding the value of n (which I assume will be the value for L seeing as it can be equal to n). These include using the Plotkin bound, which resulted in the value for n being smaller than the given value of k. I've tried using the definition in the image below and using Matlab to solve the inequality, resulting in there being no value for n (?)
I'm not really sure how else to approach this question.
Am I missing something simple/obvious here? Any advice is greatly appreciated.
« Last Edit: October 30, 2015, 12:45:52 am by tec5c »
Re: nk block codes
« Reply #1 on: October 30, 2015, 12:46:20 am »
Bump.
Offline Marco
Re: nk block codes
« Reply #2 on: October 30, 2015, 01:15:56 am »
Lets google block code.
Lets try to find the part most likely needed to solve the problem :
"A code with distance d allows the receiver to detect up to d-1 transmission errors"
So we need d >= 11.
"For maximum distance separable codes, the distance is always d=n-k+1"
Now I'm going to make a small jump in logic which I think is plausible, but which I'm not going to prove because I'm far too lazy. I think it's logical that if we calculate n according to the above equation then for that value or higher values d >= 11 can be guaranteed.
So n >= 10+k, L >= n, so L >= 10+k.
I honestly don't see why L was even brought into it, but experience dictates it's just poor problem construction rather than anything meaningful.
Re: nk block codes
« Reply #3 on: October 30, 2015, 04:43:51 am »
So we need d >= 11.
If the code is guaranteed to correct t=10 errors, then d >= 11 does not seem correct.
Seeing as, d <= 2t + 1
So shouldn't d <= 21? Then continue on with your approach.
Then errors detected = 20.
Regardless, thank you for your reply.
« Last Edit: October 30, 2015, 04:45:32 am by tec5c »
Offline Marco
Re: nk block codes
« Reply #4 on: October 30, 2015, 12:29:05 pm »
BTW rather than invoking MDS for that equation it's probably better to say you are using the Singleton bound.
Re: nk block codes
« Reply #5 on: October 30, 2015, 12:41:41 pm »
MDS?
Using the Plotkin bound was just one approach I had tried... Singleton appears to be the way to go.
Offline Marco
Re: nk block codes
« Reply #6 on: October 30, 2015, 12:46:08 pm »
Maximum Distance Separable codes.
Re: nk block codes
« Reply #7 on: October 30, 2015, 12:59:27 pm »
Ah yep. I see what you mean now.
Also, out of curiosity, do you work in the comms field? Or just a HAM or something?
Offline Marco
Re: nk block codes
« Reply #8 on: October 30, 2015, 01:05:23 pm »
No, just some deja vu from my college days.
Re: nk block codes
« Reply #9 on: October 30, 2015, 01:11:06 pm »
 Well you have some fine memory retention skills then  :-+
Thanks for your help.
