Author Topic: New Rigol DC PSU's  (Read 158819 times)
Offline mcinque
  • I know that I know nothing
Re: New Rigol DC PSU's
« Reply #375 on: September 15, 2015, 11:22:03 am »
Bump. Also did Rigol fix the overheating issue with the LM317?
Whoa, yes! Many months ago.
Offline NikWing
« Reply #376 on: September 19, 2015, 02:03:43 pm »
hey all :)
I'm currently pondering to buy a DP832, but though I searched a lot, I didn't find exact answers to my questions.
Maybe someone can help me out :)
AFAIK the 832 is the same as 832A, except that the A has all options and a multicolor skin? No hardware differences?
if I use the cookie gen to unl0ck the 832's options, it will be a 832A after I'm done. With no differences?
Will there be the multi-color skin as in the 832A?
And, if I want to upgrade the firmware later, I have to use 832's firmware or is it identical for both versions?
Thanks a lot for any reply! :)
Offline PA0PBZ
« Reply #377 on: September 19, 2015, 02:33:33 pm »
Offline NikWing
« Reply #378 on: September 20, 2015, 02:46:41 pm »
PA0PBZ: yes, beside the colored buttons, what about my questions ^^;
Offline PA0PBZ
« Reply #379 on: September 20, 2015, 02:58:19 pm »
I don't think the multicolor display is an option you can enable, but the resolution and interfaces are easily hacked.
Offline NikWing
« Reply #380 on: September 20, 2015, 03:05:14 pm »
ok :)
I try to decide between these 2 and I kinda like the colored display more (how the values are displayed and kept apart by different colors)
but I don't know if it's worth the 300+ EUR if everything else is the same after using the cookies
and if the hardware is the same, I wonder if there's just 1 firmware for both and the device knows if it's A or non-A because it's set in some eeprom or whatever, I didn't yet find out about that
Offline PA0PBZ
« Reply #381 on: September 20, 2015, 03:08:16 pm »
I have a fully unlocked DP832, and never tried to find out if the multicolor display is possible on this unit. I just don't like that display...
