Good morning, Update, all boards installed. Went through the troubleshooter for 24v rails and on to
10.4 the Shaper and Output Amplifier. As always it starts with clearing the error code by pushing the LCL key all this does is display the stuck key error "o". The reset pin on U30 is at 5v grounding it for a moment does nothing. Checking the voltage at CR501 &2. it's not a full +/_ 15v. OK! NEXT step set it up for XXX and check the output?
I need to just STOP. .... OK regrouping.
1. Yes, I have no 24v rails, (A problem on the -24 rail).
2. But it seems, I need to find out why it's not completing the self-test first. or is it?
3. I can't find the information to diagnose this.
4. Is it in the manual and I'm missing it?
5. Is this what it looks like when the RAM, (which is the next step in the boot process fails?
Can I please get some help? I know there are many experienced HP warriors familiar with the 8116A in this group. I want to keep this. I really don't want to see this on E-Bay, Parts only.
