Author Topic: NI GPIB-USB-HS - Issues - no original - fake - HACK? - firmw replac from orginal  (Read 4455 times)
Offline max-bitTopic starter
As in the topic, the problem of a large number of adapters :  NI GPIB-USB-HS
From software version 17.6 (NI 488.2) all Chinese adapters (mainly bought on ebay) are detected as not genuine.
So far the solution is to use software version 17.0 (which is also not available on the NI website).
But is this the only solution?
According to me, there should be at least 2 more:
1 - finding a module (entry) in the software which, after detecting an incorrect number, throws this error.
2 - (or even better) find the entry in the adapter's flash memory where the serial number is and change it
Has anyone tried to deal with the topic?
So far, I have not been able to find such an entry neither in the software nor in the memory of the adapter, most likely this value is encrypted in some way.
Although we may be able to achieve something together.
« Last Edit: September 02, 2021, 11:22:29 am by max-bit »
Offline georgd
  • Country: cs
Re: NI GPIB-USB-HS - Issues - no original - fake - HACK?
« Reply #1 on: August 29, 2021, 08:13:16 am »
At first glance, I suspect to serial number stored in separated I2C EEPROM. NI in the recent version of his software put to the backlist the device whom EEPROM contents has been cloned.
The solution is to reprogram the serial number in the mentioned memory. If you have access to at least one genuine NI adapter, compare its content with the genuine one.
Reading out EEPROM without desoldering  is elaborated on car radio forums.
Georg
Offline tv84
  • Country: pt
« Reply #2 on: August 29, 2021, 08:20:42 am »
Go here.
« Reply #3 on: August 29, 2021, 01:41:14 pm »
I understand that it is enough to upload this file
And it is gonna be fine ? checked ?
https://xdevs.com/doc/National/GPIB-USB-HS/fw/good_eeprom_24lc256.BIN
« Reply #4 on: August 30, 2021, 04:44:17 am »
Hello, is anyone there? Someone will confirm?  :o ;D
« Reply #5 on: August 31, 2021, 05:50:57 pm »
above firmware is ... no orginal SN 014F3A71
« Reply #6 on: September 02, 2021, 09:23:10 am »
f..ck ... programmed eeprom 24lc256 (from original unit) serial no. changed in NI MAX but software still sees it as not genuine? WTF?
Offline Scratch.HTF
On a related topic, is Agilent (Keysight) doing something similar regarding fake (and even cloned) 82357 USB-GPIB interfaces?
If it runs on Linux, there is some hackability in it.
and are there such fake?
Offline gslick
Offline E Kafeman
    • AnTune VNA software
Fake Agilent GPIB-USB? No they are all original and new. Now for sale due to that they bought too many in Hongkong at $600 each, now selling them with $500 loss.  :-DD https://www.ebay.com/sch/i.html?_from=R40&_nkw=82357B&_sacat=0&_sop=15&rt=nc&LH_ItemCondition=3
No signature
Offline bdunham7
What error do you get when this happens?
Proper solution is not to use bloated NI software in first place.  :)
What do you suggest instead of NI-Max?
And what does GPIB Agilent Keysight "fake" look like? (PCB Chip) orginal & fake ? PICTURE PLEASE
NI insade are the same.
Fake : ?
  |O
and
BIG Fake :
https://sigrok.org/wiki/GPIB-USB_82357B_clone  :-DD
and...
Offline Kosmic
I posted some pictures over here: https://www.eevblog.com/forum/testgear/test-equipment-anonymous-(tea)-group-therapy-thread/msg3232212/#msg3232212
Offline Smokey
  • Not An Expert
Wow.  That's a good fake.  Do you think they ran these on a ghost shift or did someone not only try to copy the schematic, but the layout as well?
Offline Kosmic
Most likely they copied the PCB and enclosure and are populating with the parts they can find.
Online coromonadalix
A fake for a start
#1  Doesn't have copper paint as a shield, and the copper is supposed to be seen from the screw holes in the plastic shell
#2  The serial number has been blacklisted
#3   working eeproms dump  repositories  somewhere ??? .....
It's getting complicated to follow many threads    as i needed an usb gpib adapter and was going with the arduino  gpib route ...
