I turned my UT-61E on, dial straight to volts mode, and pressed "Peak". I have a small 12 DC motor attached, and I want to find the peak output when I spin the shaft. I spin it a couple of times, then the meter starts double-beeping, about once a second... any ideas?
Here's what it's doing:
