Anybody know what the replacement fuses for this meter are or a better replacement. Paper manual was in Chinese, and the online manual states
A mA range: F1, 1A H 240V, 6x25mm (CE)
10A range: F2, 10A H 240V, 6x25 mm. (CE)
I can not find fuses that are 6x25mm. Should they be Fast, Slow, Medium blow?
Don't trust the rated CAT on the meter, so certainly won't use in anything about CAT2 so no point in sourcing out 1000v fuses
