Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Fluke 87 III Over Load indication.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Fluke 87 III Over Load indication. (Read 1577 times)
firewalker
Super Contributor
Country:
on:
July 02, 2018, 03:57:51 pm »
Some time my Fluke 87 III displays an Over-Load on volts scale without anything connected. A simple tap on the rotary switch is enough to fix it. Bad contacts?
Alexander.
Logged
Fungus
Super Contributor
Country:
Re: Fluke 87 III Over Load indication.
Reply #1 on:
July 02, 2018, 09:00:14 pm »
Certainly sounds like it.
Pull it apart and rub them with spit, that usually does the trick.
Logged
retiredcaps
Super Contributor
Country:
Reply #2 on:
July 02, 2018, 09:57:57 pm »
See
http://mrmodemhead.com/blog/fluke-83-iii-rotary-switch/
"It basically works and seems to be calibrated correctly, but occasionally when set to measure Ohms, the display will flicker a bit and only display “OL”, regardless of whether the leads are connected to anything, or even shorted together. A slight tap on the rotary switch will cause it to start working correctly again. Odds are, there’s a minor problem with the internal switch contacts."
Logged
firewalker
mzacharias
Frequent Contributor
Country:
Reply #3 on:
July 04, 2018, 12:56:48 pm »
DeOxit D-100L. Apply directly to switch contacts. Do not use a spray cleaner.
Logged
firewalker
Fungus
Super Contributor
Country:
Reply #4 on:
July 04, 2018, 01:45:24 pm »
I refer you to time 12m02s in this video:
Logged
firewalker
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
