19.9Kohms. I think my guess about the RMS chip was right. There is more green stuff on it than anywhere else. Pin 1 on the chip has it the worst, with 2 through 7 having some too, but even pins 8-14 have some. The purple cap C19 must have leaked and somehow also contaminated the top legs of it.
EDIT: After taking another, very close look, C19 was so bad that the through holes on the bottom seem to have come off. The trace on the bottom going from the negative to another through hole also started to come up a bit. I'm positive that wasn't the problem originally, but it's something else that should probably be fixed.
I really wanted an 8060A since they're cool and oldschool and I need one for testing stuff in my little recording studio but I probably shouldn't invest any more time or $$$ into it.
