The Electrician;Another thing I notice is that the numbers for sweeps/second on the Anritsu don't make sense to me. I set it up to look at a local TV station (a digital signal here in the U.S.) at around 600 MHz. Using a 5 MHz span and 10 kHz RBW, the instrument reported a sweep time of 900 mS, but the update rate on the display is much faster than that; I would estimate about 50 mS. I see this behavior constantly; the unit is much faster than it indicates. They must mean something different than what I would expect by the term "sweep time". The FSH4 doesn't behave like this. It reports a sweep time that is consistent with what you see on the display.
I just had the chance to audition a Anritsu MT8212E (I believe). Surely not what I was looking for, but it gave me a basic feel. Among other things, one thing I was looking for was the lowest sweep speed it could do. Not having a manual for this (the rep was suppose to have a 2712), we (both of us) were perplexed with the readout of sweep speeds. I had the unit in manual RBW, VBW & what I thought was a manual sweep setting, but it still had a mind of it's own. It let me enter slower or faster speed speeds, but it would then display what it wanted to. usually some odd number; 83, 167ms etc.
On top of that, when trying to enter in another number, the display went into some other setting, what appeared to be a 1 sec sweep even those the readout was around 100ms.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
I'll report back on mine and his findings as he did contact Anritsu for this and other questions.
One thing I surely don't like is their manuals, they are terrible. They do
not show a complete Menu tree. Only for the "File" and "System" menu entries. Nothing for all the other 'important' operational entries. You know, the ones that are used all the time.
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
The fastest speed it did show was 50ms depending on settings.
