You can try reseating the chips. For now, though, rather than pulling them and risking pin damage, I'd just give each of them a push down while supporting the board beneath it. You may hear/feel a slight 'click' as the chip moves in the socket. If just pushing yields no clicks or movement, perhaps pry them up *just a touch* with a small screwdriver - just till it moves. Either end should do it, it's not even necessary to lift both as just the movement should shift all the pins slightly. Then reseat them. If there's oxidation, this may break it.
Does yours have the battery, or not?
What does it indicate on, say, DC volts with no input and/or the input connections shorted together?
-Pat
