Thanks a lot for Fluke 77 pics, Dave!
I have Fluke 179 which is quite similar. It helps to track down layers of tracks, because on mine the top layer is not that transparent.
I have an issue with Fluke 179 precision. Ohms range shows about 30M when should be OL, and around 30 ohms when closed and decreasing to ~1 ohm for about a minute. (probes are fine)
VDC shows about 250mV on open loop when should be 0. Internal resistance is about 11M (sounds fine to me) and sending 1mA to probes when measuring resistance.
VDC on 9V battery shows difference from other DM about 0.2V.
I've measured reference voltage on pins 10,11 on IC and it's 2.5V. MOVs shows high resistivity (OL on my Voltcraft MT-52). Also measured some testpoints to discover abnormality. Most of them was 0.8V, one 4V sharp, TDI/TCLK shows about 0.05V
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
, P2.1/TB0 was negative
I'm not an electrician, just enthusiast, so just investigating from every sources I can get.
If someone can lead me to what I can check or when I can find that leak, I would be grateful.
