Hi all,
I was fiddling around with 2 Fluke 87's (III and V models) at work today due to some down-time. I happened to notice that the 87 V has ~2.7v across the probes when in the ohms range. I was curious to know why this is the case. Compared to the 87 III model that only had ~0.6-0.7v across its probes in the ohms mode.
I couldn't find much info doing a Google search, other than the service manual but I haven't read through that thing just yet so I apologise if the answer to my question is in the manual/is quite obvious.
Cheers.
