I'd start checking whether the CPU runs and what the address lines do. Problems like these won't get solved by just swapping components blindly. In the end you can swap all the components without any luck because there is an open trace somewhere on the PCB. Another thing to try is reseating all the socketed devices (=lifting the chips a bit from their sockets and push them down again) .
