@Gandalf_Sr This is the one I bid on and won!
Yeah, you beat my max bid by $5
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Hope it is a good one for you. I'm going to hold off on the Fluke for now, I wanted a high end meter that could log data on its own but I can't justify $550 for the Fluke - just too much IMHO.
So I just picked up a used
Keysight U1242C - which comes with a U1173B IR-to-USB cable - from Keysight on eBay for $204 plus tax (6%) - I made a 95% offer on their asking price and paid a total of $217.
The U1242C features:
– 10,000-count display
– Up to 0.09% basic DCV accuracy
– Battery life up to 400 hours
– Certified to IP 67 for water and dust protection
– Tested to withstand a 3-meter (10-ft) drop
– CAT III 1000 V / CAT IV 600 V overvoltage protection
– Harmonic ratio measurement to quickly identify the presence of harmonics in AC signals
– ZLOW, low impedance mode to eliminate false readings caused by stray voltages
– Vsense for non-contact voltage detection
– T1 – T2 differential temperature measurement
– Built-in flashlight!!!!
This will collect up to 2,000 readings stand alone, can connect to the Keysight Meter Logger software that I have on PC and iPhone, it has 1-button capture and download, plus I already own the U1117A Bluetooth adapter that allows up to 100 m range connecting to the meter. The Fluke 289 has 100-200 hours battery life, 15,000 reading storage and a graphic display to look at the results but that's about it as far as I can see.
Thanks for all the help and encouragement.
