Hi all.
I recently found a cheap vintage Tektronix P6045 online, which is a 230 MHz FET probe, the input impedance is roughly 10 MΩ // 4 pF. I think it may be a useful low-capacitance probe for some hobbyist projects, for example, RF at 30 MHz. Do you think it is worth buying? The spec is here:
http://w140.com/tekwiki/wiki/P6045Anyway, the biggest problem is the power supply. Tektronix officially designed it to be used with the 454/454A scope that has a power port. Alternatively, with the 015-0073-00 power supply that provides the same power port, it's basically nothing more than two +/- 12.5v linear voltage regulators (built in the late 60s with Zener diodes and discrete transistors, the glorious days), which I think is not worth buying for, and can be easily recreated by two LDOs, or even the crude 78xx.
But the power connector is nowhere to be found. Tektronix just call the power connector on the probe a "keyed 3-terminal male snap lock type with grounded shield". I also managed to find a photo of the socket on the power supply as well, i attached the photo, but no additional information.
TekWiki is unable to confirm it either, it says "The 015-0073-00 (power supply) has a 3-pin probe power connector (Sealectro 55-850-0018-98?)", note the question mark, and worse, I was unable to find that Sealectro part. I also took a look at the 454/454A scope, which featured the same 3-pin power socket, but again couldn't find additional information.
Any suggestion on the candidates for the power connector is appreciated. Thanks!
